Help with '76 distributor wiring
Old Jun 11, 2010 | 07:09 PM
V8 Stingray's Avatar
V8 Stingray
Default Help with '76 distributor wiring
Guys, I've been cleaning up the wiring in the car and I need some advice with the distributor wiring. I'm waiting for my new colour wiring diagrams from Doc Rebuild - so could really help with a dig out on this.
The car had a Mallory Hi-Fire 6 ignition system in the car before, but its since been removed but the cables are still running down under the carpets inside the cabin as below (they are now capped).
These are the four wires which the loop connector comes from (some cables changed colour due to Bubba's wiring skills! :silly: )
It looks like another block was used in order to connect the ignition system to the HEI distributor. You can see the mess of the cables, its a wonder there wasnt a fire already! Anyway I'm looking to remove this extra wiring/connector and just hook up the stock config - is the plan in the picture right?
Old Jun 11, 2010 | 11:43 PM
OMF's Avatar
OMF
It looks to me that in pic#2 the tach wire is connected to the distributor. In pic #3 you have a wire labled as "the stock ignition wire". Take this wire and plug it into the distributor where it's labled "Batt". That should put this mess back into the stock configuration.
Hpoe this helps
Old Jun 12, 2010 | 04:26 AM
V8 Stingray
Thanks dude - that's what I thought..... but when I go to start the car now, the start kicks in, and the car fires somewhat but it dies and wont stay running... like as if I have a wrong connection.
There is fuel getting to the carb, so wondering is it the three wires that come from the bottom of the distributor to the terminal block behind the NEG and BAT connectors.
Old Jun 13, 2010 | 11:27 AM
OMF's Avatar
OMF
The wires that come out of the distributor casting come from the ignition module, and plug in behind the tach/ power wires. Disconnect the power wire and check to see if you have 12v on that ignition wire with the ignition key on but car not running.
Is that a stock ignition with just an accel cap on it?
Has this setup worked previously for you?
To Help with '76 distributor wiring
