1976 Tach Problems
Old Jun 12, 2010 | 10:16 PM
Scott Marzahl's Avatar
Scott Marzahl
Default 1976 Tach Problems
I just had all the gauges restored, installed the dash and the tach worked great, shut off the car and next time the tack spun around and stopped at 7K and when started went to 2,500 and stayed. What the heck, is this a new board that failed already?
Other issue is I turn on the lights and the left turn signal indicator bulb in the dash lights up so I guess I need to start looking for a short to that blue wire too. I pulled the relay but no luck.
Old Jun 12, 2010 | 11:28 PM
...Roger...'s Avatar
...Roger...
Check the 3 wire connector at the left front signal,probably lost the ground to the socket. I dip the whole socket in body etch acid to clean.
Old Jun 13, 2010 | 03:50 PM
Scott Marzahl
Thanks Roger, between a new flasher and cleaning that ground to the driver's front bulb took care of it, now to figure out that tach problem.
I also just discovered that the headlight switch will not power the dash or console bulbs and I have good grounds. I need to install a couple headlights and see if they light up or not as well. Can these headlight switches fail just a portion of the contacts?
Old Jun 13, 2010 | 05:19 PM
...Roger...
Your Welcome.
Check the INST lamp fuse to see if either side of it is hot when the HL switch is pulled.
The fuse is actually fed "from" the HL switch and then from there goes to the dash lights.
Yes portions of the HLS can fail , the usual failure is the dash light portion.
Old Jun 13, 2010 | 11:50 PM
Scott Marzahl
Default Tach update
Well after a day of screwing around trying to figure out what could be wrong with the rebuilt tach I took a close look at the new tach board and found a lose spade terminal. I hooked it up to the car's harness and with every wiggle the tach would either work or go haywire. I resoldered that terminal and so far so good.
Thanks again Roger, I had a faulty INST light fuse, you couldn't see it but when I checked it with a meter as suggested, no power. Replaced the fuse and I've got dash and center cluster lights. Getting this thing wrung out one step at a time.
Now to get the horns to work and I've got a new horn contact installed and verifed a good ground as well, with my luck the new contact will be bad or something else in the column.
Old Jun 14, 2010 | 07:35 AM
...Roger...
Tell me about it , I had a 67 Chevelle SS with 236 miles since the restoration in last week. The brand new horn contact was junk as were many other items used in the rebuild.
Old Jun 14, 2010 | 11:37 AM
08vycpe's Avatar
08vycpe
Jim Shea has a paper that will walk you through the horn diagnostics.
Old Jun 14, 2010 | 01:44 PM
Scott Marzahl
Thanks for the tip, I just downloaded Jim's horn paper to add to my steering column paper's collection.
To 1976 Tach Problems
