What carb??
Old Jun 14, 2010 | 12:04 AM
ssenay72's Avatar
ssenay72
Default What carb??
I'm pretty sure i've had it with this holley 4160 (non adjustable float) , i can't get it to run right.
SO that said, road demon 625?? Suggestions?
Edelbrock intake, msd hei, headers pypes duals, electric fan. Stock 350 l-48 1975 car. Only changed the timing chain and gears. Stock cam. Not going to change anything else, i'll be getting a crate motor in a year.
Which carb can i get peak performance with, WITHOUT messing with it too much. Drop it on, set the idle, mixture and go.
HELP!
Old Jun 14, 2010 | 09:22 AM
Fishndude's Avatar
Fishndude
You can buy the Summit carbs for about $200 and in my opinion, that is a steal!! The summit carbs are designed, wet tested and also set up for a street/strip application and I think they are one of the best deals on the planet.. I had one and it ran as good as my new BG Mighty Demon 750dp..
Old Jun 14, 2010 | 02:02 PM
ssenay72's Avatar
ssenay72
i dont care what it costs, you get what you pay for. i jsut want it to work.
To What carb??
