Big Block Pulley's
Big Block Pulley's
Will these pulley's work on my big block?
I'm looking at part 655-7510 on this page
http://www.jegs.com/cgi-bin/ncommerc...095&prmenbr=76
The only accessory on my engine is an alternator, I don't have power steering or AC. They say they are for a short water pump. I don't need an idler pulley unless I'm running AC, right?
I think 169 for all 3 is about what I'd spend on stock used ones anyways.
Re: Big Block Pulley's (Steve Straus)
You're probably fine unless you use the Corvette water pump with the 3/4" shaft. The other water pumps have a 5/8" shaft I think.
Re: Big Block Pulley's (john73bb)
Senior Member since 1492
Let me know, cause I'm in the same boat as you!
Len
Len
