Electrical Issue - 1980
Old Jun 16, 2010 | 03:06 AM
Stooney's Avatar
Stooney
Default Electrical Issue - 1980
I haven't quite found a solid pattern for this but sometimes the interior lights will stay on with the car off and doors closed. Without changing anything, the lights may turn off properly. It does not seem to be the springy things that detect if the doors are open/closed.
Also, the radio will turn on fine until I turn on the headlights, at which point the radio loses it's power.
Generally after losing the radio power due to turning on the headlights, I can not get power back to the radio for a little while (even without lights).
Where should I look for problems?
Also, most of the gauges do not work. On the panel above the radio, the fuel gauge works, but nothing else. Power is hooked up to it, and the battery light stays lit. There is not obvious issues with the battery.
Any help is greatly appreciated. I just obtained this car a couple days ago and am trying to work out some of it's bigger kinks. It runs great.
Old Jun 16, 2010 | 08:17 AM
Crash80's Avatar
Crash80
The interior light timer is located behind the glove box in the 80 as I recall. They can fail and cause oddities. With your gauges and batt light, check the actual printed circuit board that all that stuff is attached to. I had to replace one behind the speedometer as it started to separate and caused the ground to fail. Once that happened I had a constant choke light and buzzing relay to go with it... then the blinker indicators in the dash quit indicating which is why I replaced the PCB to begin with. Doing that, fixed the choke light and all those issues as well to my surprise. The center PCB in your car may be failing similar to mine. That is where I would start, though the issue could be elsewhere.
Old Jun 16, 2010 | 08:51 AM
wombvette's Avatar
wombvette
The gauge, radio problem is a ground, and is probably in the circuit board. That is a common problem with these.
Old Jun 16, 2010 | 12:09 PM
Stooney's Avatar
Stooney
Thank you both. Do either of you have a link to where I can buy a replacement? I googled '1980 corvette pcb replacement' with no luck. I don't know correct terminologies for this stuff yet
Edit: Is this it? http://www.ecklers.com/corvette-dash...1978-1982.html
Old Jun 16, 2010 | 12:43 PM
Crash80's Avatar
Crash80
Willcox
http://willcoxcorvette.com/product_i...ducts_id=25311
There are two, one for the speedo/tach cluster and one for the center console area.... You want the center console area, the one I linked.
Here is a link showing both:
http://willcoxcorvette.com/advanced_...php?cPath=2059
Old Jun 16, 2010 | 01:47 PM
Stooney's Avatar
Stooney
Originally Posted by Crash80
Willcox
Thank You. I will be ordering this today as I'm pretty sure it's the problem. I remember the PCB being loose when I was installing the radio yesterday. Would you happen to have installation instructions on hand?
Also, aside from the PCB where would I look to check grounds? I'm not completely sure which ones I'm looking for, but where would I look? (If that makes sense)
Old Jun 16, 2010 | 01:55 PM
sniperdiver37's Avatar
sniperdiver37
it pretty simple...remove center guage cluster (screws on both sides and on top) unplug... remove the cluster bulbs, nuts around the back of the guages... remove... replace. I was told that the oil from your hands will cause the CB to fail sooner, so wear rubber gloves. Key word in all this is "gental"
Old Jun 16, 2010 | 02:03 PM
Crash80's Avatar
Crash80
Willcox has a really cool section of repair help, doesn't cover everything but is really helpful:
http://willcoxcorvette.com/advanced_...+%23&x=43&y=16
Old Jun 17, 2010 | 01:25 AM
Stooney's Avatar
Stooney
Thank you all so far. Last major question for this thread:
Where would I look for the ground for the radio? So far the radio seems to work during the day, but not at night, regardless of headlights. I'm not saying this is why, it's just the only pattern I can find for when it does/does not work. I guess I could just reach in there, find the ground and ground it myself to see if that helps.
Old Jun 17, 2010 | 04:28 PM
my 76 ray's Avatar
my 76 ray
Sounds like you have the AM radio. You should get the AM/PM radio.
Old Jun 17, 2010 | 07:01 PM
Stooney's Avatar
Stooney
Lol nah, it's an aftermarket stereo. I'm to the point where I have the radio working solid as long as I don't use the lights. Turning on the lights cuts off all stereo power.
We're gonna go through the wiring diagrams and see if we can find the problem. My friend asked me to ask you fellas if it could be the headlight switch bad/going bad. I believe this is all related to the issue of the interior lights occasionally being stuck on.
To Electrical Issue - 1980
