Power Brake Conversion
TSW
Keep in mind; I’m doing this from memory so if anyone wants to add to this feel free!
You will need both the power brake booster and a new master cylinder. Power brake and standard brake master cylinders are different.
The cars with standard brakes have two studs on the firewall; you will need to knock these out of the firewall (they will fall inside the car).
Then using the two upper holes from the studs as a guide, mark the lower holes and drill them for the lower booster holes.
Once you do this, you’ll need to enlarge the hole in the firewall for the rod from the power brake booster. Yes it bolts to a different position on the pedal but doing this is real easy. If you look under your dash you’ll see a round hole on a non power brake car. On a power brake car it was egg looking. The inside reinforcement should for both power and standard had this egg looking hole made in to it and if you look under the dash you’ll see what portion of the fiberglass you’ll need to remove.
The standard brake and power brake lamp switch bracket were different, the power brake one is now available new. http://willcoxcorvette.com/product_i...ducts_id=12540
Hope this helps, I used to have a detailed sheet somewhere on this when we did a conversion many. .. Many years ago. If I can find this I’ll post it for you.
18243Willcox Inc.
Thanks for that info, I've printed it out, and I know it'll be of great use. I couldn't use the link for the part, can you print the part number so I can order one.
"Then using the two upper holes from the studs as a guide, mark the lower holes and drill them for the lower booster holes".
Those aren't the two holes from the stud's that I just knocked out, are they?
http://forums.corvetteforum.com/c3-t...er-brakes.html
