I've been installing new front & rear suspension parts from VBP and I need to know how to install the front shock tower brace.
The car is a 1969 big block with electric fans, I ordered the prewelded brace.
If anyone has already done this and has some pictures to share, I'd sure would like to look at them!
Also, who makes aluminum upper and lower a-arms for the C3?
I run this bar on my 1980, dual electric fans. Bolted right in, easiest mod I have made so far. Pretty self explanatory. Watch your alignment shims, as you loosen the bolts to slip the brackets on each side, they will be loose as well, keep a couple of fingers on them.
From: Graceland in a Not Correctly Restored Stingray
If your looking for fixed length aluminum upper CA's try SpeedDirect. Guldstrand and others offer fully adjustables. Don't recall a source for aluminum lowers, but there are several for tubular steel ones, including for coil-overs and semi-coil-overs.
Thanks Skunkworks, do you have the web sites for some suppliers of these control arms?
Also, what ever happened to Speed Directs aluminim lower control arms, it's been awhile since the said anything.
Please dump that fuel filter! The people that still sell these dont care about you. No, it is not the glass that is the issue.
