Alternator Pulley diameter
Old Jun 18, 2010 | 09:13 PM
ssenay72's Avatar
ssenay72
Default Alternator Pulley diameter
Would a smaller or larger alternator pulley, turn the alternator more or less one way or the other?
I'm wondering if my power drop is because the march perormance pulley is larger than the pulley that the powermaster comes with.
Old Jun 18, 2010 | 09:16 PM
TimAT's Avatar
TimAT
All about ratios- a smaller pulley will turn the alternator faster, bigger is slower. You can find a calculator to work out the ratio from the diameter of each pulley too.
Old Jun 18, 2010 | 11:03 PM
ssenay72's Avatar
ssenay72
So im probably better off with the smaller one then?
Old Jun 19, 2010 | 07:50 AM
thegazman's Avatar
thegazman
Default thegazman
I installed the March pulley system on my 79 L-82. I changed the alternator pulley back to the smaller pulley I had because my alternator wasn't charging well at idle. After changing back to the smaller pulley my charging problem was corrected.
Old Jun 20, 2010 | 04:47 PM
TPI BOY's Avatar
TPI BOY
What is the diameter of your pulley
Old Jun 20, 2010 | 11:38 PM
noonie's Avatar
noonie
It's common in high draw, long idle situatations like limos to go to a smaller alt pulley to get more at idle. Look at alt output charts for rpm output.
To Alternator Pulley diameter
