Beefing up an '80 rear end
Old Jun 21, 2010 | 10:58 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Beefing up an '80 rear end
Ok so I know what kind of power I am making and I want to get some real timeslips, that means drag radials and doing whatever to the rear of my Vette that needs to be done to launch the car properly. 14 secs @ 114 mph with a 3 sec 60ft gets old real fast.
The aluminum Dana has held up quite well with street tires acting as a relief valve and spinning instead of sticking and destroying the rear end parts.
So I would like to know what you guys have done to '80-82's to make the rear end stronger for a good launch at the drag strip. I will be around 500 RWHP. Opinions are also welcome, I will be collecting parts to do this over this winter
Old Jun 21, 2010 | 11:23 PM
SIXFOOTER's Avatar
SIXFOOTER
I quizzed Gary quite a bit about this a couple yrs ago. With $$ not a show stopper, a Tuned iron unit from an older vette would be the answer. There is not enough meat in the aluminum units and there is really no good way to blue print them. SOme can be done, but it didn't seem worth the effort to me.
Old Jun 21, 2010 | 11:37 PM
MotorHead's Avatar
MotorHead
Gary won't touch an aluminum punkin. I don't want to spend a fortune but I know me once I get into it, it's gonna hurt.
Just want to know my choices. Has to stay IRS no straight axle. Would love to here from someone who is running the same or less HP with a clutch and able to launch fairly hard to real hard. What parts they had to change / use. Automatic is fine too
Old Jun 22, 2010 | 12:28 AM
jordan89's Avatar
jordan89
I'm subscribed. I want to hear what can be done to these IRS to handle the power. I want to know what I would need to do when I build my engine.
Old Jun 22, 2010 | 12:41 AM
Bee Jay's Avatar
Bee Jay
I'm with you on this one Motorhead. I just bought an aluminum rear for my Vette. But I'm sticking with street tires and automatic transmission. You are my example that the aluminum rear end isn't all junk.
Bee Jay
Old Jun 22, 2010 | 08:41 AM
...Roger...'s Avatar
...Roger...
I thought Gary just had one of these for sale that was beefed up out of his sons car ?
Old Jun 22, 2010 | 08:59 AM
The Money Pit's Avatar
The Money Pit
So far I have hit 7000 rpms on the 1/2 shift and haven't heard anything break in the rear. I have not yet tried a full on launch in first......Should be interesting. With my street tires, it would roast them from a 25 mph roll in first, and keep them boiling through third.
These MT's are sticky, which is what I needed....But now I have to work up the nerve to hit them hard off the line. I suspect my 3000 stall and almost 500 ft lbs is going to hit pretty hard. Mind you this car has not been on the track,...just playing around once in a while.
The rear is the stock aluminum one, but I put 3.70 gears in it about eight years ago, and all U-joints are solid.(No grease zerks)
Old Jun 22, 2010 | 09:26 AM
DRIVESHAFT's Avatar
DRIVESHAFT
If you get in touch with tracdogg2 (Mike) here on the forum, he can fit a billet steel cap to the aluminum rear end that should help.
I still doubt it would hold up to the power that you are making with sticky tires though.
I switched over to a iron differential in my 80, but I am sure its still not strong enough for serious drag duty.
You would probably have to get one done up 12 bolt style to be able to really beat on it without worrying.
Old Jun 22, 2010 | 10:08 AM
AutoX-Z06's Avatar
AutoX-Z06
12bolt with upgraded half-shafts and outer/inner spindles.
Old Jun 22, 2010 | 11:03 AM
ajrothm's Avatar
ajrothm
With 500rwhp and a stick shift on drag radials AND going to the strip, I would damn sure go with an iron diff and at a minimum, do the "Super 10 bolt" from Tracdogg or GTR1999.....but the full 12 bolt internals upgrade would be your best bet for sure.
I am having Tracdogg do a Super 10 bolt with the 30/31 spline axle setup in August, I drag race but my car is an Auto so I think it will live...especially since I am only going to run a 3.36.
Both Tracdogg and GTR1999 have excellent reps for building these things, lucky for me, Tracdogg is within driving distance for me.
You get your car to hook and you can shift, you "should" blow into the 10s...good luck....it's about time you start putting all that power to use...
Old Jun 22, 2010 | 01:54 PM
MotorHead's Avatar
MotorHead
I actually got tired of drag racing ( my own cars ) years ago but since last year the interest has come back.
I think I am going to be sinking some big money into the rear to handle the power and stick shift. If I am going to do I will do it all the way that mean best launch possible and shifting at 7000 RPM's
I was browsing the DragVette site, he has a interesting and cool looking 6 link setup it looks like he bolt right to the aluminum Dana rear, I still think the diff is going to blow if I did that, even an older iron case won't last.
Looks like a 12 bolt of some kind is in my future. Would like to see this thread go for while and get some guys who have converted the rear ends in there '80-'82's for big power. It could be used as a reference
Old Jun 22, 2010 | 04:02 PM
ajrothm's Avatar
ajrothm
Do your research on the DV 6 link..... I had a thread running on it a few months ago and most that had it on a street car didn't like it. If you can limit the squat, you will limit some breakage...the DV 6 link basically just corrects geometry during a squat but...doesn't do anything to strengthen the rear end other then taking the load off of the half shafts by not using them as a stressed member in holding the wheel/suspension in place. They work well for that but it doesn't do crap for sheering posi units, ring gears, outer axles etc.
I think that $900 would be better spent on a severe duty rear spring, QA1 dbl adj shocks, all new bushings and ofcourse towards the mortgage of a 12bolt IRS, 30/31 spline axles, 3" thick walled half shafts or even 3.5".
Put good parts in the diff, stiffen the hell out of the rear to limit squat.
I am going through all of this crap myself deciding what all to do. I am pulling the trigger at the end of the summer...... About $4k down the tubes....and that's just for a super 10 bolt.
Old Jun 22, 2010 | 04:21 PM
MotorHead's Avatar
MotorHead
Yes I read some of that thread and do know what it does. I just never looked at it closely. What was interesting to me when I first looked at was the fact he was using the aluminum Dana 40. I personally know that diff is much stronger than anyone gives it credit for.
That said NFW is it gonna handle a wheels up launch on slicks, I was thinking about a cheap easy route but I don't think there is one. It looks like a 5 grand upgrade is what I'll be doing.
Now that said what exact parts are we looking at. 12 bolt diff to start now and add the rest of the parts, from who and which parts to use. Mines an '80 so it might require a bit more modifications than previous years ? .....
Old Jun 22, 2010 | 04:30 PM
...Roger...
Could you use this with your aluminum rear cover ?
http://www.vettemod.com/forum/showthread.php?t=5921
Old Jun 22, 2010 | 04:53 PM
MotorHead's Avatar
MotorHead
Roger, at this moment I don't know what will fit or what I need. I would like to turn this thread into here's what you need for a bullet proof IRS for C3's.
I am obviously only interested in what an '80 needs. It would be nice to have a tidy list of all the parts, part numbers, approx. prices and where to get all of these parts. Maybe someone has them all in one place I don't know, or could put a package together
Old Jun 22, 2010 | 04:54 PM
ajrothm's Avatar
ajrothm
First you will need an iron diff. Not sure if any year case is better then the other...but either way you will need an iron case. Toms Differential is the only show in town. Other vendors just resale Toms stuff so....go to Tom direct and save the middle man mark up.
For the best of the best:
12 bolt internals kit...$1750
HD axle kit (30/31 spline inner/outers), 3.5" half shafts and flanges etc...$1988
HD cover.....$150
Ofcourse you need adj struts, a good spring, good shocks etc if you don't already
have these items.
Labor to rebuild the trailing arms(to install big bearings/31 spline axles) $500-700+
Labor to machine everything in the 10 bolt housing for clearance for the 12 bolt guts, machine all guts, install and correctly setup $500-700+,,,(rough estimate, probably more...)
It ain't cheap. A MINIMUM of $5k assuming you already all some of the suspension stuff. In reality, it's upwards of $6k
I was just quoted $4000 for Super 10 bolt which is basically the same except no 12 bolt ring/pinion and no 12 bolt posi carrier....and I already have the good half shafts.....but that was with a full trailing arm resto....
Old Jun 22, 2010 | 04:56 PM
MotorHead's Avatar
MotorHead
I had mine up to 6500RPM in second yesterday, the rear will handle the power that way. But I wouldn't leave the line on sticky tires at anything over idle
To Beefing up an '80 rear end
Old Jun 22, 2010 | 04:58 PM
ajrothm's Avatar
ajrothm
Www.tomsdifferentials.com
Old Jun 22, 2010 | 05:02 PM
MotorHead's Avatar
MotorHead
HD cover.....$150
Ofcourse you need adj struts, a good spring, good shocks etc if you don't already have these items.
Labor to machine everything in the 10 bolt housing for clearance for the 12 bolt guts, machine all guts, install and correctly setup $500-700....
Yeah thanks that's the kind of info I am looking for. I don't even know whats involved in swapping in an older iron diff. yet into my '80 with the aluminum batwing.
But the way I do things I would imagine everything is going to be changed from the trailing arms to... well every part behind the end of the driveshaft.
Old Jun 22, 2010 | 05:27 PM
hugie82's Avatar
hugie82
I've seen wrapped up halfshafts, blown U-joints and cracked carriers but I haven't seen an aluminum rear fail from to much horse power/torque
