autogear m21y, some help...
Old Apr 14, 2011 | 02:13 PM
elle88's Avatar
elle88
Bought the M21Y stuff a while ago...
it seems that next week it's time to install the new gearset and new clutch , pressure plate and throwout bearing.
my mech is well experienced in overhauling european transmissions, but should he pay special attention with the M21? i mean : is there something peculiar to muncies that i must know before to start?
Old Apr 15, 2011 | 06:03 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
5speeds (Paul C) sells a comprehensive Muncie build DVD.
Are you certain with your power that you want to go this route??? I'd really suggest talking to Paul about the M21Y before committing to installation.
As for performance alone, after the extensive acceleration modelling I've done with C3's having very similar power curves and available traction I'd change the diff ratio to a 3.55:1 and think about either M-22Z extra-wide ratio gearset or a 5-speed w/OD than to go with the M21Y setup. FWIW, with a 3.55 FDR in top gear, approaching terminal velocity will likely be a rather dodgy proposition without some aero tweaks anyway, and with an OD altogether impractical without a good bit of aero work. Of course, you may have other priorities to consider. Just some food for thought before you take the plunge.
Old Apr 15, 2011 | 06:38 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
D&D Viper-Chevy T56
650 lb-ft Torque Capacity
1.125 x 26T GM Input Spline
30T Viper Output Spline
Close Ratio w/ Deep Overdrives(2.66/1.78/1.30/1.00/.80/.62)
Carbon Fibre Blocker Rings
Steel 3-4 Shift Fork
Precision built and blueprinted by D&D technicians
Direct bolt-up to GM Saginaw/Muncie/T10 bell housings
Direct bolt-up to 4-Speed aftermarket steel bell housings
Accepts stock GM clutches,linkage,T.O.B.,pilot bearing,trans. mount
7T GM Mechanical Speedo Drive or Electronic Speedo Drive
Old Apr 16, 2011 | 10:07 AM
elle88's Avatar
elle88
TSW , 63mako
of course there are many better solutions than M21Y and 4.11 but all more expensive than the usd500 of the M21Y gearset. it has been a matter of budget. My 4.11 is fine , why replace it?And i want my car to remain stock appearing , that's why i have never decided for an aftermarket transmission
I look forward to drive the car with the new gearset.i don't know if I'll find myself comfortable with that gear spacing. let's see... but i wanted lower rpm in the higher gear , both at cruise speed and when going fast
Old Apr 16, 2011 | 10:31 AM
63mako's Avatar
63mako
Originally Posted by elle88
TSW , 63mako
I understand your point. The D&D trans is what I have for the 63 with a Tom's 12 bolt 4.11. It is all expensive though. You have a wide but high RPM powerband and tons of torque from 4500 up. With a high RPM shift point you will be fine as long as you don't powershift it.
