Power brake conversion
Old Jun 25, 2010 | 07:31 AM
omegac1's Avatar
omegac1
Default Power brake conversion
I have a 1968 with power steering and manual brakes. I want to convert to power assit brakes. Has anyone used this JEGS conversion kit?
http://www.jegs.com/i/JEGS/555/63105...oductId=948187
Tx
Mike
Old Jun 25, 2010 | 11:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Can't say about the JEGS kit. If you do not have the '68 assembly instruction manual (AIM) buy a copy and take a look at the factory installation of the PB option.
There is also a page in the AIM concerning the various holes which have to be drilled/cut in the cowl. Power brakes requires a different size hole than manual brakes.
Old Jun 26, 2010 | 06:41 AM
omegac1's Avatar
omegac1
ttt
Old Jun 28, 2010 | 07:08 AM
omegac1's Avatar
omegac1
ttt
Old Jun 28, 2010 | 08:58 AM
Bob Heine's Avatar
Bob Heine
Tx
Mike
Mike,
If you only want to know about the JEGS kit, I can't help you (you might want to include "JEGS" in the subject line if that's what you're interested in).
You can get a Tuff Stuff booster and master cylinder for about $25 less. I guess the JEGS kit comes with the vacuum hose and fitting and maybe a pushrod for the extra money.
Summit has the Tuff Stuff parts (also available in chrome) and their page gives you a bit more information:
http://www.summitracing.com/parts/TFF-2129NB/
I think it's the same amount of work with either one and that work is covered in the other "Power Brake Conversion" thread.
http://forums.corvetteforum.com/c3-t...onversion.html
Sorry if this doesn't answer your question -- maybe someone out there has used the kit and will eventually respond.
To Power brake conversion
