Connection issue after electronic Tach conversion
Old Jun 25, 2010 | 06:49 PM
johnt365's Avatar
johnt365
Default Connection issue after electronic Tach conversion
This is an electrical question for ya.
I had the tach for my 74 converted to electronic by Roger at Corvette Clocks. I am about to lose my mind installing it though.
The issue is the tach works fine UNTIL I connect any of the 5 little lights with the metal clips to the back of it. There is no issue if i connect the light with the rubber grommet.
Once I connect one of those lights, the tach moves backwards to 5500 or so and stays there, engine on or off.
I guess it is a ground issue but dont know how to resolve it.
Do I need to ground the speedo and tach cluster? I see they have a metal strip between them.
please help if you can ,
John
Old Jun 25, 2010 | 06:52 PM
'75's Avatar
'75
Yes each of the clusters, speedo and tach as well as small gauge needs to be grounded.
Old Jun 25, 2010 | 07:00 PM
johnt365's Avatar
johnt365
Thank you! Now I am trying real hard not to blow anything up and could use some guidance on how or where to attach the ground to the clusters.
Do I run a ground wire to the metal pan where the lights connect into? how is it grounded from the factory? and is it ok just to run a new ground wire there.
Old Jun 25, 2010 | 07:11 PM
...Roger...'s Avatar
...Roger...
I think you need to call Roger. If the dash lights are not turned on they are supplying the tach case with a ground if its not already grounded by one of the 14 black wires.
From what your describing it sounds as if you might have installed something wrong. Just a guess but I'm thinking when you run a separate ground its going to do the same,could be wrong,I'd call Roger.
Old Jun 25, 2010 | 09:46 PM
johnt365's Avatar
johnt365
If anybody knows how this cluster is grounded I would like to know. Thanks
Old Jun 25, 2010 | 09:50 PM
...Roger...
Both the speedo and tach should a 14 gauge black wire going to them. The spade is screwed to the cluster housing.
Old Jun 25, 2010 | 09:55 PM
...Roger...
The 2 holes on each side of the red arrow are for a bracket , one of the screws holding the bracket held the ground spade.
Old Jun 25, 2010 | 10:44 PM
johnt365's Avatar
johnt365
This really helps, thank you. After 3 years I have clearly forgotten how this was put together.
I found the ground spades and connected the ground connectors and still have the issue. I think it is safe to say that I have a ground problem. However it confuses me why the tach works when out of the cluster and not in the cluster.
Thanks again Roger.
Old Jun 26, 2010 | 07:11 AM
...Roger...
Look to see if the input signal coming from the dist is somehow connected to the metal housing that the lights fit in. Maybe a missing fiber washer ?
Old Jun 26, 2010 | 12:08 PM
johnt365's Avatar
johnt365
Just as I was about to give up I noticed one of the rubber washers was broken on one of the screws. I removed the screw and it seems to have fixed it.
I will call Corvette Clocks monday and order a replacement rubber washer.
Thanks!
To Connection issue after electronic Tach conversion
