Gauge Removal
Old Jun 27, 2010 | 09:17 PM
skapvette's Avatar
skapvette
7th Gear
Default Gauge Removal
What is the correct tool to use to remove the center console trim plates surrounding the gauges on my '82? I can't tell if it is a Torx or Allen.
Old Jun 27, 2010 | 09:24 PM
'75's Avatar
'75
I'm not sure about the 82, but on the 78, those screws are fake.
Old Jun 28, 2010 | 04:35 PM
doctorgene's Avatar
doctorgene
Yes Sir; You remove the gauges from the rear. Take your two Console side panels off, remove the two hidden screws ( W/ nut wrench on mine) under sides of the shift console plate, from the center gauge bezel, one on each side. The two side screws, one on each side, remove, then the two in the top of bezel. Remove the radio ***** & retaining nuts. Slowly pull the whole gauge section out. ( I find it is a lot easier to remove the speedo & tach. first. Reach in behind gauge panel an Unplug the main wireing loom. Watch how the light plug in top of bezel, watch Air Cond vent hook up. Have a ball. Gene
To Gauge Removal
