Help...Stalling Problem with '86
Old Jun 28, 2010 | 10:26 AM
Biker's Avatar
Biker
Default Help...Stalling Problem with '86
Moved to correct section.
Old Jun 28, 2010 | 10:50 AM
wnmech's Avatar
wnmech
We need to get the moderators to move this post over to the C4 section. I am not sure about the C4 but most GM vehicles the fuel pump relay should not cause your problem. When you turn the ignition on the fuel pump relay energizes for a few seconds. Most GM vehicles the relay is also energized thru the oil pressure switch. Does your 86 have the optispark? on the F body's these are always failing.
