Help! Ball joints!
Old Mar 23, 2002 | 08:47 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Help! Ball joints! (Black68Vette)
I drove the pickle fork in as tight as I could get it then I smacked the bolt end of the ball joint for good measure. PB blaster the whole nine yards. Finally got them out. Someone said you gotta get mad at it. Must have worked for me. Cause I was beginng to wonder if I really wanted to do this at all. Now the whole front suspension is laying on the garage floor.
Old Mar 23, 2002 | 08:55 AM
killain's Avatar
killain
Oldtimer
Are you putting the fork inbetween the knuckle and the boot on the ball joint? and are you allowing the lower control arm to hang? To do so you need to keep the nut on the ball joints pin so that once it breaks loose it is held in place by the nut. And as youhammer on the ball joint aim the fork downward so a lot of the pressure is directed on the ball joint itself. It will brake loose with a slight popping sound, and make sure the floor jack is right underneigth the lower control arm so you don't have the spring pop out. Think positive, it'll come loose.
Old Mar 23, 2002 | 09:07 AM
mrvette's Avatar
mrvette
You know, the sharks have a dumb looking arrangement,...are you damn sure you got the TOP nut off the lower ball joint, they insert from the bottom....and have a nut on the bottom of the joint itself that holds it to the lower controll arm....so it's the TOP nut that has to be loose....they can be a bitch but a propane torch, and a good wack with an OPEN THROATED ball joint pickle fork will do the job....in fact, I only have ONE pickle fork...one intended for tie rod ends, as I recall, and I opened up the throat to take most ball joint stems diameter...my fork is allmost 3/4 inches thick at the end of the throat...that should pry apart any ball joint I ever seen....on a car anyway...
I only use a 3 lbs hand sledge....
GENE
Old Mar 23, 2002 | 09:32 AM
Noel Carboni's Avatar
Noel Carboni
Although actually Noel, I don't see how dropping the control arm first (if I could manage to do it without getting killed by the spring) would help with getting the balljoint shaft out of the knuckle on the spindle
Sorry; that WAS confusing, wasn't it? :crazy: I only mentioned that to give you a feeling of security in case you hadn't thought about it... Putting that much force on things can sometimes cause damage to nearby things (like the A-arms). In my fog last night I didn't think too hard nor remember that it was you who was upgrading to VB&P just like I am.
-Noel
