1977 Brake Caliper Tools?
Old Jun 30, 2010 | 08:44 AM
81_vette!'s Avatar
81_vette!
Default 1977 Brake Caliper Tools?
Replacing the left rear caliper - and wondered if there was a Torx screw/bolt to be dealt with?
If so, what size? (T-55?)
I am putting on a loaded caliper, but wanted to get any special tool needed before I get to the shop.... so I don't have to go back to the store later.
Thanks a million!
Old Jun 30, 2010 | 09:19 AM
tomnt's Avatar
tomnt
If everything is factory, no special tools required.
Old Jun 30, 2010 | 09:59 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
There is a tool that holds the pads in place while you slide the caliper over the rotor. You can certainly do without it but it'll go faster with it. It's a simple tool made of sheet metal and is available at all of the Vette parts dealers.
Otherwise, you should only need fairly standard tools.
Old Jun 30, 2010 | 03:24 PM
Speed Direct's Avatar
Speed Direct
Premium Supporting Vendor
Nothing special is needed but have a line wrench or some vise-grips to get the brake line fitting loose. Be very careful not to round the nut.
To 1977 Brake Caliper Tools?
