water temp guage quit working
Old Jun 30, 2010 | 09:37 AM
vetteonbeach's Avatar
vetteonbeach
Default water temp guage quit working
I changed the plugs out and knocked the temp gauge sender wire loose without knowing it. I took off on the test ride only to notice the temp guage wasn't working anymore, but the little plastic plug already melted from the exhaust manifold. I cut it back and "stuck" the metal clip portion on the sender and the guage still doesnt' work - it is pegged out whether the car is off or on...
so what exactly did I tear up and what do I need to replace?
thanks
Michael
Old Jun 30, 2010 | 10:57 AM
SIXFOOTER's Avatar
SIXFOOTER
should not have hurt anything. With the key on, ground the green wire that goes to the temp sensor, gauge should move. Your probably just not getting a good connection. If you have a volt meter there are a couple more checks you can make.
