ignition lock cylinder
One other thing, I think you are refering to the ignition lock cylinder that is sticking out of the right side of your steering column housing. The ignition switch is mounted on top of the steering column down under the dash. The switch is actuated by a rod that moves when you rotate your lock cylinder.
Make sure you disconnect your battery before working on the column.
To remove the lock cylinder you will have to remove the steering wheel, remove the lock plate, and pull the turn signal switch up and out of the way. Place the cylinder in the RUN position and now you will be able to reach into the rectangular slot in the column head and depress the locking wedge that is part of the lock cylinder. You should now be able to pull the lock cylinder straight out of the column head.
New lock cylinders are available from any GM dealer as well as many automotive parts stores.
If you consider that a Corvette T&T column is just a glorified tilt column you should be able to use my steering column disassembly papers that I have posted at http://www.corvettefaq.com. Look under Suspension and Steering. There are several papers and pictures that should help you. If you have a standard (non-adjustable) column the Corvette standard column papers at that same sight should also be very similar to your column.
If I can be of further assistance, you can eMail me or post your questions right here.
Btw, when it comes to pulling the steering column and lock cylinder, I would encourage you to do two things. #1 - use your GM Service Manual #2 - take digital photos or good notes so that the reassembly isn't a "where does this go?". Finally, if you decide to replace the ignition cylinder, the GM Service Manual tells you to use a piece of stiff wire to pull the plastic key buzzer out. I didn't have wire stiff enough to remove that stubborn switch. Since this switch is nothing more than two pieces of copper strip held in a fragile plastic housing, I didn't want to break it. I "encouraged" it to come out using a dental pick. Once that is out, the GM manual is very descriptive on removing the cylinder. As a final note, my local locksmith shop carries these cylinders and they are identical to the one in my car. Somewhere around $35 for the cylinder and $20+ to rekey it to my key.
Gary
Good luck.
Bill http://www.locksmithasap.com
Another possability is that your truck is slighty newer and will be retained by a screw. If after moving the turnsignal platform out of the way you see a TORX headed screw (on some transition years it may not be a TORX head)that appears to pass just below centerline of the lock cylinder, you have a screw retained lock rather than the discussed spring retained cylinder. You have to remove the screw to pull the lock out and it makes no difference what position the lock is in. "Locked" position is best to aid in reassembly. With the screw removal, you will probably have a piece fall out that looks like a little plastic box with a flat spring. This is the switch that makes that "buzz" if you leave your key in the ignition, off. On reassembly, just ensure it is in place and work the head of the TORX screw around it. It should be a pain, but obvious. The tool mentioned is worth the money. I see them all the time in parts stores for about $15.00. Also, getting a key cut from code is always a good ideal. Never waste a good exact-replacement key blank on your older Vette by duplicating your worn key onto it. It has always amased me to see guys spend time and money to search for original key blanks, then take them to the local department store or hardware store and have some kid copy their old worn key on to it. Spend the few bucks to have it recut to factory specs by a compotent locksmith. Of course this costs more because it involves some research, setup and milling maching type cutting.
One thought on the new cylinder, which may or may not be of any importance to you. When you walk into a parts store or GM and buy an over-the-counter replacement, it's going to be with a set of keys completely differant than what you had. If you would like to get a new cylinder to match with the original key cuts, like,,, to match the doors or glove box, or to just stay original, a locksmith will build you one with the matching code to your original key. Usually just little more than off-the-shelf cylinders.
Again, good luck.
