Carb help
Old Jul 2, 2010 | 03:01 PM
68sting's Avatar
68sting
Default Carb help-vapor lock or something
I just got my car back on the road today. I cruised around for awhile (no hood) and stopped at a fiends house for a few minutes. When I started the car up all was fine until I hit the accelerator and gas came pouring out of the front vent tube on the carb flooding it. I started it back up and gave it some gas and raw gas shoots out of both vent tubes and onto the windshield. Any ideas what this is? It ran fine after this initial incident.
Old Jul 2, 2010 | 03:39 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Sounds like something has gotten between the needle and seat and is holding it open. Sometimes all it takes ia a little bit of dirt. That or the float is stuck.
Old Jul 2, 2010 | 06:23 PM
68sting's Avatar
68sting
I checked the float level when I got back home and they were fine at that point. Should I just drive it a little more and see if the crud gets out or do you recommend I take the bowls off and have a look. Thanks for the help.
Old Jul 2, 2010 | 07:05 PM
0Paul Ruggeri
Former Vendor
There is a risk of an underhood fire, so I would check it out right away.
Old Jul 2, 2010 | 07:21 PM
sjr1971's Avatar
sjr1971
You have a problem with your carb. A Rochester ? If so, your air valve should be closed at idle. When the engine loses vacuum at high RPM ,that releases the air valve above the secondary butterfly valve; it also pulls up the secondary rods that supply gas through the secondary jets to to the secondary's butterfly valve
Old Jul 2, 2010 | 07:27 PM
68sting's Avatar
68sting
Its a 750 holley from the Carb Shop.
Old Jul 2, 2010 | 09:52 PM
Timsride's Avatar
Timsride
You have to check the needle and seat, You probably have something stuck in there. It is probably too big to go through on its own. Are You running an external filter?
Old Jul 3, 2010 | 12:16 AM
68sting's Avatar
68sting
I am but the carb has been of for a while now.
Old Jul 3, 2010 | 05:41 PM
68sting's Avatar
68sting
I put the hood on today and went for a spin. I'm getting an old problem that I never fixed. I'm having a vapor lock issue I believe. When it does this the carb appears to boil over. I run a Holly blue pump thats mounted in the back. Next up is the mechanical filter and then the regulator that has a pressure gage. My pressure will drop to 0 and you can hear the pump surging. It will stay at zero long after the car has been sitting. I switched pumps and regulators but same problem. Any ideas on this?
To Carb help
