here is a pic of the motor i put together for my moms truck it was a weak v6 now its a 355 with a mild cam flow masters... she thinks it's cool.. i guess its what you do when your waiting for your vette is engine is tied up at the machine shop for three months
Reason: messed up
i have been doing a ton of research on the mark 8 lincon fan conversion.. i really like the fan. so after a little deliberation and a night to sleep on it i pulled the trigger and bought the mark 8 fan from a local junkyard 50 bucks i tested before i left man it moves some serious air.. so i pulled the radiator.. here goes nothing i found a awsome link about mark 8 fan conversion here's the link malibuthunder.com
thank you 75' ! what did you guys think about that link the pics to me looked pretty strait forward.. my only concern is what am alternator do i use? i have a DVD player and a small stereo system in the car but thats it. so im thinking atleast a hundred amp would suffice.
Glad you've gotten back on track with your 496. Might you post a complete link to the fan conversion?
Happy 4th
thanks, im glad to have it back i really wanted to have this b.b in my car by the 4th. but i decided to do the radiator up grade. and a Happy independence day to you!! i will do a write up on the mark 8 fan conversion
What did you buy for a block that was $2200.00 i would of gone to the auto wrecker and bought a complete 454? and used that. Tons of good 2 bolt main blocks out there, i studded mine and made 1006 HP with it never had a problem with it. Off the bottle it made 708 HP and 622 tq.
Did you get that 1000+ hp 2 bolt out of a junkyard for less than 2200 dollars???
The Block was a STD bore 454 2 bolt main block. We put main studs in it, bored .060 line bored the block and that was pretty much it. I bought an Eagle rotating assembly with internal balance and the better SRP pistons and a .250 longer rod, as well as the L-19 rod bolt. The heads were AFR 305 rec ports with a Dart intake and 1000 cfm pro-systems carb. The cam was a custom ground unit from Cam Motion. .691/.684 lift with .262/.270 @ .050 on a 112 LSA. Solid roller. I soon learned that i needed a bigger cam, and also that i should of went with the 4.25 stroke crank and built a 496.
We made 6 motor only dyno passes and 3 nitrous passes on the dyno. In a 3500 lb camaro which was set up to run nitrous and not motor only. we ran 11.20 @ 119 on the motor and a best of 9.65 @137 through a 2.5" exhaust mufflers and tailpipes.
I can email you the dyno sheet if you like? So dont call my 468 build BS just because i didnt spend $2200.00 on a block that wasnt needed.
The block was a 4 bolt 454 for $400 dollars, the machine work to disassemble, clearance,deck,clean,new piston rings, new cam bearings,new crank bearings, bore, hone ,degree the cam, and assemble was $1800 together it was $2200
Ok sorry my mistake, I was under the impression that your bought a Dart block? I also had a heafty bill from the machine shops as well. But balancing and blueprinting is worth the money to make sure it stays together.
sorry about the bs comment, no hard feelings grumpy just a slight mis understanding ill keep you guys posted day to day on the updates.. im missing car show season!!
Vidio of the car running! trying out the mark 8 fan i seems to keep the car under 210.. the fan comes on at 185 and off at 175..<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/y3RC5fmeC6E&color1=0xb1b1b1&color2=0xd0d 0d0&hl=en_US&feature=player_embedded&fs= 1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/y3RC5fmeC6E&color1=0xb1b1b1&color2=0xd0d 0d0&hl=en_US&feature=player_embedded&fs= 1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385"></embed></object>
