Turn signal short?!?
Old Jul 10, 2010 | 07:02 PM
Kap142's Avatar
Kap142
Originally Posted by ...Roger...
Oh ... did the back up bulbs light ?
Offical wifey says "yes they did." Tomorrow I'll chase the burned wire approach.
You're an ace dude. Thanks so much.
Ken
Old Jul 14, 2010 | 12:14 PM
Kap142's Avatar
Kap142
Default this is what I found
Wish I could get my imagining working correctly so I could attach a pic but. I found where "bubba" had run the back up switch wiring so that each time the clutch was depressed it encountered the wire eventually creating a ground. I also found a total of four (yes I said four) splices in those same wires, one of which was simply twisted together then wrapped with duct tape.
After a bit of system clean up and repair all seems just fine again.
I guess that's what you get when you're the 4th owner of a C3.
Again to all who offered direction esp Roger I thank you.
Ken
