Slight "sputter"
Old Jul 7, 2010 | 05:31 PM
ue73's Avatar
ue73
Default Slight "sputter"
I just put a new holley 670 on my 73 w/350 190hp 4spd.I put new points,cap,rotor,wires.I adjusted points with a dwell and set initial timing with a timing light.I drove the car and it "sputtered" alot in 1st and 2nd around 1500rpm.I called holley and they told me adjust the floats which I did and the car ran 100% better but now when I slow down and take a turn and start to accelerate I have a slight "sputter"I have plenty of gas in the tank but just can't figure out why this is happening.I did notice when I was setting the timing and hooked up the distributer vacuum line there was no change in idle.could this be the problem or another one I should add to the list.thanks for any and all help.
Old Jul 7, 2010 | 08:16 PM
marz's Avatar
marz
Just throwing it out there from what I ended up doing, Try removing the vacuum line to distributor and plug the port at the carb and the distributor and see if it smooths out. That's what I did on my ride when it was sputtering.
Old Jul 8, 2010 | 11:48 AM
ue73's Avatar
ue73
i'll try that and see what happens.if it runs ok like that does it mean i need a new distributor or can i leave it like that.
Old Jul 8, 2010 | 04:36 PM
FKING1's Avatar
FKING1
There are several possible probs with the 670. Make sure the accelerator lever is on the cam not off of it.
Also, my 670 came with 65 & 68 jets which are a bit lean and will cause a stumble.
Put the 68 secondary in the primary and a 72 in the secondary.
I ended up with 72 & 80's in mine and it runs great.
Old Jul 8, 2010 | 05:33 PM
marz's Avatar
marz
You can. But, if that doesn't help it may be a jet problem. I also had to go through a series of jet sizes because it was running rich.
To Slight "sputter"
