Too Much Oil Question
Old Jul 9, 2010 | 09:36 AM
  #41
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by MotorHead
Forgot to mention please post your MPG after you drain a quart
I am sure you, like myself, are highly skeptical of any change in mileage.
Old Jul 9, 2010 | 09:52 AM
  #42
Steve439's Avatar
Steve439
Wow show me some documentation that backs that up or I will tell you your high school teacher is an idiot, actually worse than that they can be dangerous
Um, that was my point.... why I included the shift point comment...
Old Jul 9, 2010 | 10:06 AM
  #43
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Then we agree !
Three pages because someone had too much oil in there motor ain't this forum great or what
Old Jul 9, 2010 | 04:33 PM
  #44
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Then we agree !
We never decided whether too much oil will cause a rear main seal leak.
another old wives tale?
Old Jul 9, 2010 | 04:45 PM
  #45
MotorHead's Avatar
MotorHead
Yup old wives tale actually the opposite of overfilling is a main cause, as in not enough oil in the motor can cause the rear seal to dry out and then leak if you fill it up again. Or storing it for a long time the seal will dry up and leak or the seal will just get wornout from old age just like any other part in the motor.
Another thing that cause it is an out balance rotating assembly which will wear the seal unevenly causing it to leak
Overfilling it a qt means you can drive it longer without having to put oil in it
