Door Striker Question
Old Jul 8, 2010 | 10:29 AM
Petes73's Avatar
Petes73
Default Door Striker Question
I am replacing the striker on my 73. My question is do I have to remove the molding in the storage area to get to the nut that is holding it on, or will it stay in place? I checked the little door in the wheel well that you get to the alarm wiring through but I could not see the nut there is a foam barrier that is lower than th striker.
Old Jul 8, 2010 | 12:33 PM
jnb5101's Avatar
jnb5101
it's a welded nut attached to a plate that has some movement for adjustment. just unscrew the striker, the backing plate won't go anywhere.
Old Jul 8, 2010 | 01:02 PM
Petes73's Avatar
Petes73
thanks I thought it was somethning like that, but it is easier to ask than to be wrong
To Door Striker Question
