timing question again
Old Jul 9, 2010 | 04:34 PM
ue73's Avatar
ue73
Default timing question again
when timing my 73 w/timing light the mark on the balancer "jumps" from 12deg mark(which is what i need).it will stay on 12deg for about 3-4 seconds then jump around for a couple seconds and go back to 12deg.over and over again.why? bad distributor?
Old Jul 9, 2010 | 05:16 PM
myk7's Avatar
myk7
Is this with the vacuum disconnected from the distributor? What rpm? Could be sloppy timing chain, week machanical advance springs in the distributor or a vacuum problem if the vacuum is still hooked up to the distributor.
