door problems on my 81
you best bet is the tag that hangs of the mechanism is bent and the loc rod does not always engage slipping out of the hole where it would normally sit. i will see if i can dig up a picture of this.
if your key is turning the loc as normal and the **** on the inside is functioning as normal then i dont think there is going to be any other way then to buy some beers, take the panel off again and sit there with some patience and loc/unlock/lock /unlock and see what the problem is. possibly its your door handle shaft is out of adjustment...there is a small barrell which moves up and down to adjust the height but unfortunatly i think the door handle has to come out for that and there isnt alot of room to get at the 2 x 1/2 nuts that hold it on.
i have had my doors in my 81 apart many times and can pretty much do things with my eyes shut but finding the problem is the hard part with your problem. what changes when you get the door open, is it just persistence and it just finally unlocks? is everything in there lubricated including the door catch?
i hope you have patience .
at the bottom of this rod is the barrell adjuster
and here is the small loops on the end of the barrell that can completely miss the rod.
