After I finish my ls1 swap I plane to run a wider wheels to utilize the l88 flares.does anyone happen to have pitures with rallyes atleast 10" or wider?
turtlevette
i like how your rear tires look. where to buy those 15x10 rallies?
i was thinking to those just for racetrack , not street, so if they stick out of fenders is not a problem. i suppose that rally 15x10 should be the cheapest one the market, or am i wrong? I bought some 15x8 Minilites as standard wheels but 15x10 minilites are expensive just for some random race track day
turtlevette
wheel vintiques
although i just checked their site and 15x10's are unavailable.
Rears are 15x10 5"bs and fronts are stock rallys. The 15x10s almost fit but just slightly interfere with the tie rod. A grinder on the tie rod could probably clearance it.
The e-brake brackets had to go. Most everybody knows about that. My 5 leaf steel spring was flat enough not to interfere with the tire. When i swapped to fiberglass i had to shorten the spring. Some people don't like doing that but mine hasn't split out yet. I remember using a hand sledge to slightly bang in the trailing arm to prevent it slightly kissing the tire. Oh and forget running a rear sway bar. It will definitely interfere.
Now if he's running big flares, he could easily go 15x10 or maybe 15x12 with 4" BS.
From: Graceland in a Not Correctly Restored Stingray
Thanks turtle. Agree moving the e-brake bracket and eliminating the rear bar (I don't run one anyway) are a given. So, no frame clearance issues, eh? I'm leaning towards staying old-school, but some of the section widths I'm looking at appear they could present a problem with the 5" BS. I forget, what brand/line tires are you on?
What i'm going to try next are some dirt track tires i picked up cheap.
I've had them sitting around since March. I need to get them mounted! Hoosiers. Should look bitchin.
