Power valve issue?
Old Jul 11, 2010 | 04:29 PM
68sting's Avatar
68sting
Default Power valve issue?
My car has been flooding out almost like its vapor locking. At times I have had gas shooting out the vents. I checked vacuum today and it was 9 in neutral and 5 with the clutch slightly engaged for a load. My power valve is a 65 and I realize I need to change that. Which number should I use to select a power valve. Would this be my overly rich problem?
This carb worked fine a 1200ft but since moving to Colorado (6600ft) it seems to be giving me fits. Does elevation effect vacuum?
Old Jul 11, 2010 | 08:08 PM
Timsride's Avatar
Timsride
I would try to get the vacum higher, but if you can't I would put in 3.5 power valve or valves depending weather carb has one or two. I would also think that the car would run richer at higher elevation because air is thinner.You may want to try leaning out jets and idle mixture first. Just my 2 cents worth.
Old Jul 11, 2010 | 08:44 PM
Grumpy 427's Avatar
Grumpy 427
I was going to say 2 sizes smaller in number with your car in drive and your foot on the brake. Not sure how to do it in a standard.
Old Jul 11, 2010 | 09:59 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Last year, when I went to the NCCC Convention at Colorado Springs with drag racing at Bandimere at nearly 6000 feet above sea level, I had to re-tune my carb from its previous setup at 500' - to 6000'. This involved cutting the fuel metering areas by 8%, advancing the spark by about 2 degrees, and changing the enrichment vacuum threshold by about 2" Hg. The latter means that if your 6.5" PV was fine, try a 4.5" PV. If you have a Quadrajet, use a softer power circuit spring.
Old Jul 11, 2010 | 10:44 PM
68sting's Avatar
68sting
How do I get more vacuum? I did rejet and on the dyno my air/fuel mixture was good.
I'll try a 45.
Thanks. I'll bump it down a couple sizes.
Old Jul 11, 2010 | 11:02 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Fuel shooting out the vents is a Needle and seat issue or air in the fuel system, PV can't cause that issue. If its rich at idle you may have a bad PV, blown power valve.
the elevation change should cause it to be lean not rich.
need to figure out why the vacuum is so low at idle
Neal
Old Jul 12, 2010 | 10:15 AM
larrywalk's Avatar
larrywalk
Originally Posted by chevymans 77
Fuel shooting out the vents is a Needle and seat issue...
...the elevation change should cause it to be lean not rich.
Nope. Less air at the higher elevation will cause it to be rich.
...need to figure out why the vacuum is so low at idle
At 6,000 feet of elevation, the atmospheric pressure is only 24" Hg (~12 psia) unlike the pressure at sea level of 29.92" Hg (14.7 psia). Therefore a perfect vacuum at 6,000 feet can only be 24" Hg. There is no way to have a higher vacuum at that higher elevation.
As a rule of thumb, figure all engine vacuum will be 20% lower at 6,000' than at seal level.
Old Jul 12, 2010 | 09:15 PM
chevymans 77
My mistake, I read his post to be 12000' instead of 1200'
20% would mean he had 11" at 1200' to get 9" at 6000', still sounds low unless he's running a good size cam which he could be didn't see any specs on the engine.
the elevation change can definitely cause a rich condition
Neal
Old Jul 12, 2010 | 09:24 PM
68sting's Avatar
68sting
Thanks for the info. I put a 4.5 PV in and it doesn't seem to smell as rich at an idle now. I'm still having my flooding problem though.
How does this lower vacuum at a higher elevation effect my vacuum secondaries. It seems like they're opening up late.
Here's the specs on my cam and it's in a 509BB. Any reason my vacuum would be this low?
http://www.compcams.com/Cam_Specs/Ca...?csid=445&sb=1
To Power valve issue?
