1981 vette, stock 350, still running all ECM parts. Hole shot from dead stop is sluggish, but once takes off she runs fine, will set you back if punch the gas once on the street. Run 93 octain gas only.
New carb, Q-jet installed, new fuel pump, gas tank cleaned out, all lines blown out or replaced on fuel system.
Any comments will be great if can help solve this terrible hole shot/take off problem.
i take it you are running a auto box ? What is she like if you hold her on the brake, increase the revs to say 1200 to 1500 rpm and then floor it if she takes off really well i would think that a higher stall converter would work a treat.
Where did you get the Q-jet? Who rebuilt it? There is a post currently running here started by Lars on the quality of the accelerator pumps made for the Q-jet. Find it and read up, you may find that is your problem.
The 81 Corvette came with either a 2:72 with a 4 speed or 2:87 rear gear ratio, with the automatic. These kind of gear ratios are not designed for drag racing or strong launches. The gears in the 81 were used to improve fuel mileage and not for ultimate acceration. I think what your experiencing is typical for 81's. If you want stronger launches, or more buttom end acceration, you may want to concider a switch to a shorter (higher numerical) rear gear ratio.
Didn't memtion in original post that it is a 350 automatic. The engine just goes sluggish when pushing the gas form a dead start, but picks up quick once RPMs are up. Now if stomp on it it is better but a nice normal acceleration it is sluggish. Have to have around 800 rpm in drive to not be sluggish.
Going to replace ERG valve tomorrow for it is hard to push in and see if that helps.
welcome to the world of a stock 81 . Gbvettesaid it all. you have a weak motor with highway rear gears with a stock stall . you can change your gears to 355 for example and have much better launch and reduce fuel economy . then you can take the next step and go to a 2500 stall for example and lose more fuel economy. then you can go the next step and bomb the motor...end result you have launch and no fuel economy .
then you can go the next step and upgrade the motor
Drivel removed.
While those will help, it sounds to me like you have more of an issue with engine tune - could be carb or ignition related. Make sure your timing is set right and the advance mechanisms are working well. Make sure your vacuum advance is set up properly.
Then go on to the carb and check accel pump actuation, check for vacuum leaks, etc.
I agree with gingerbread man. I changed the gear in the rear diff from the stock to a 3:54, big difference. Also went with true dual exhaust also improved.....but I am considering changing the heads and a cam this winter. in addition of a 200R with overdrive. Fun on the launch and economy on the highway with the overdrive.
My '82 came with the 2.87 gears, and even-with the 3.06:1 First Gear of the 700-R4, it was pitifully slow off the line: a switch to 3.73 gears cured that problem!
One *can* build a relatively good launching car while maintaining decent, but not great fuel economy. These cars were pigs from the factory with poor breathing motors that really weren't good at anything.
I don't think someone who is worried about having a 1.5s or faster hole-shot is going to be worrying about fuel economy. (If they do, they're nuts. The money they're spending to get that car hooking could easily cover a 15 year old Honda that would get better economy than any V8 powered Corvette could dream of getting.)
were you picking at something i said or agreeing with something. im just a little lost to where drivel comes into it ?
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Didn't read the whole post but what you have engine wise from the factory is POS. Auto makes 2x as bad as far as hole shot goes. My 215HP 245TQ stock Pt Cruiser would make you look silly at the dragstrip.
Don't get me worng here I am not putting you down, I stated with a stock L48 '80 and was handed my azz by a 1993 Cavalier. Motor came out the next day.
Only this worth playing with now are litre bikes and the guy better know how to drive, nothing like looking it the rear veiw mirror and see him hunch over then sit up and take a look at the back of my Vette and say what f was that
Don't lose the faith, its a sexy machine now and potential for more power when the time and money comes along
I agreed with the bulk of it, didn't see the point(or total accuracy) of adding all the fuel economy comments. I think fuel economy can actually be improved during the progress of upgrading the car (while adding power), to a point.
Of course, when building an all-out dragster, one plans on running a fixed distance at a time.
oh yes i see sharky. i did hammer home the lack of gas economy when upgrading to certain components. i guess i didnt mean it to sound so negative but everyone seems to take fuel economy pretty importantly these days so i was just making a point that to give an 81 launch like its a 70,s BB car is going to take some $$ and generally burn some gas.
maybe it was just my jealous side coming out because as far as fuel economy goes i generally have none.
