Door Latch Sticking!!!
Old Jul 12, 2010 | 04:28 PM
hugie82's Avatar
hugie82
Default Door Latch Sticking!!!
Do any of you guys have an exploded view of the door latch mech.?
I've been oiling cleaning and it still sticks I know it's not worn out because it's the pass side and it works fine using the inside door handle but if I use the outside handle it sticks open. Then, if I work the door lock action it snaps back and works fine until the next time the outside handle is used.
PS the outside handle is new and working properly it's in the latching mech. that cost $115 to replace
Old Jul 12, 2010 | 05:55 PM
Dantana's Avatar
Dantana
weld her shut and hop in like The General Lee!
Old Jul 13, 2010 | 10:16 AM
hugie82's Avatar
hugie82
Than I can't justify having power door lock!!!
Not that I could before
Old Jul 13, 2010 | 12:06 PM
G-Sting's Avatar
G-Sting
I had good luck spraying White Silicon Grease (spray) into the door latch mechanism. It had been sticking, too. Now it works great.
Of course it could be something deeper in the door. But give it a try.
Old Jul 13, 2010 | 01:48 PM
69MA's Avatar
69MA
I had the same issue i was using WD40 and it would dry up in a month or so. I tried some silicone spray and i haven't had a problem since. Other than that you might need to remove it inspect it and if it doesn't look worn a good bath in a parts cleaner, grease it up and reinstall.
Old Jul 13, 2010 | 04:47 PM
hugie82's Avatar
hugie82
I finally got it!!! There is two holes on the latch arm and I had the outside door handle rod going to the inner hole. That caused the rod to rub on the lock cylinder arm. I have no Idea why there is two holes in that latch arm??? What a F-up design and I'm sure I'm not the only one to run into this gremlin
Thanks guys for the suggestions Even the Duke of Hazzard one...I think
To Door Latch Sticking!!!
