Upper a arm spacers
Old Jul 13, 2010 | 04:44 AM
gleninsandiego's Avatar
gleninsandiego
Default Upper a arm spacers
I am looking at a 1973 upper a arm spacers used for alignment. What is the range of acceptable thickness? From a search I have discovered no spacers at all is not a good thing. What about more spacers in the back than in the front on both driver ang passenger sides?
Old Jul 13, 2010 | 08:42 AM
KanuckZ06's Avatar
KanuckZ06
What you call spacers are really called shims, they are placed as needed when performing an alignment to bring the front end into the proper specifications.
If you are doing any work on the control arms, you should note the number and location of any shims already on the car, and reinstall them until you get the the car to an alignment shop, this will get the car close,but not perfect!
I am rebuilding the suspension on my 69 vert and just wrapped masking tape around the shims and wrote the location on the tape.
Hope this helps!
Old Jul 13, 2010 | 08:54 AM
gleninsandiego
Thanks for the reply. I am specifically wondering what shim thickness should or should not be there.
Old Jul 13, 2010 | 10:44 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
You should take a measurement of the upper a-arm towers just forward of the front alignment stud. Take a look at the link. Pic not showing for some reason.
http://www.flickr.com/photos/corvettepics/4790394456/
Old Jul 13, 2010 | 10:49 AM
gleninsandiego
What should the measurement be? And what tolerances?
I will try to take a picture of what the car looks like and post it
Old Jul 13, 2010 | 11:20 AM
Van Steel's Avatar
Van Steel
It's written on the aluminum bar. 26 3/8"
Old Jul 14, 2010 | 01:17 AM
stinger12's Avatar
stinger12
The shims adjust your caster...u need a caster gauge to figure out how many shims go in the front/back.
Old Jul 14, 2010 | 08:59 AM
vettfixr's Avatar
vettfixr
The shims adjust caster and camber. Using an equal number of shims on both sides of the control arm will move the arm in or out equally which will increase or decrease the camber (leaning in or out of the wheel). Caster is corrected by adding or subtracting shims to only one side of the control arm. This moves the upper ball joint forward or backward and increases or decreases castor as a result. The only things shims don't effect is toe in/toe out.
Old Jul 14, 2010 | 11:38 AM
stinger12's Avatar
stinger12
Correct.
Old Jul 14, 2010 | 11:59 AM
MrJlr's Avatar
MrJlr
Correct.
And toe is adjusted by the connecting rods.
To Upper a arm spacers
