Stainless exhaust pipe
Old Jul 13, 2010 | 07:07 PM
austavla's Avatar
austavla
Default Stainless exhaust pipe
Have bought a new stainless exhaust system.
How can you tell if the exhaust pipe is stainless or not?
Is the stainless non magnetic?
Old Jul 13, 2010 | 08:47 PM
72LS1Vette's Avatar
72LS1Vette
The stainless pipes in my system look a bit shiny even though they aren't polished. An aluminized system looks more like a satin grey color.
Rick B.
Old Jul 13, 2010 | 10:09 PM
vettehardt's Avatar
vettehardt
Some stainless is non-magnetic, but some are magnetic. If it's not magnetic i would say it is stainess. If it is magnetic, something else will need to be done to determine if it's stainless.
Old Jul 14, 2010 | 02:58 AM
elke_10's Avatar
elke_10
most exhaust are 304L and 316L due to its ease of welding and forming cuz it still has a high carbon content and is magnetic. compare it to the top of a pop can the silver is about the color 304 stainless is its not super shiny unless polished and more of a grayish when not finished.
with out some lab breaking down its chemical make up your not really gonna know. don't believe a company would sell you a none stianless exhaust claiming it was stainless as for you would be suing them when it started to rust lol.
Old Jul 14, 2010 | 03:22 AM
noonie's Avatar
noonie
Almost all the oems and a lot of the aftermarket use 409 stainless and it is magnetic from the lack of nickle content.
The prettier stuff is usually 304 and is not magnetic.
They should tell you what grade they used, some offer both.
Either one will probably outlast you.
Old Jul 14, 2010 | 03:42 AM
austavla's Avatar
austavla
Thanks, all of you
I took a closer look and find a stamp on the pipe that says: MAT'L 409, so i guess the pipes is 409 stainless steeel
Old Jul 14, 2010 | 05:01 AM
Solid LT1's Avatar
Solid LT1
409 Stainless steel has carbon in it, it will rust over time, about 30-50 years to failure I would think. Magnets stick to 400 series stainless not 300 series. Most cheap exhausts are 304 series stainless, high dollar stuff is 316, 321 series, more than 2-3 times the cost of 304 series tubing.
HD engine valves are magnetic, junk ones are not. 300 series is more likley to crack than 400 series Sstl. 300 series will look prettier than 400 series over the long haul. Everything in life is a compromise
Old Jul 14, 2010 | 08:50 AM
vettfixr's Avatar
vettfixr
I've had a 409 system on my car for over 20 years and it looks like the day I put it on.
To Stainless exhaust pipe
