I added PS to my BBC this summer. Since then I have been beating my head against the stock-style power steering pump and alternator bracket.
First I wasn't able to get tension on the PS pump but that was easy to solve with an adjustable rod. Now I can't get enough tension on the alternator for love or money. Part of the problem is that there's no good point to lever on it and tighten it down.
You should be running the alternator from the PS pump - I gather you are? You should not have too much tension on the alternator. If you have the right sized belt (and it took me several trips to NAPA to get the right one) you should be able to use your hand to put enough squeeze pressure on the alternator bracket and alternator body to get the belt tight enough, then tighten. I tend to wear a heavy duty leather glove when doing this - it helps.
That's how I've got it setup but I can't even get it tight enough (after a warm-up run-in) that the I can't slip the alternator pulley right under the belt.
Needless to say I have some pretty aggressive belt squealing at start-up.
ddn, post some detailed pics of your set up. Someone here might find/see the problem. Could be the brackets configuration. I know the original bbc vettes had the offset alt pulley which then ran to the ps pulley in order for it to line up. I learned this from other folks who have done the bbc conversions in there cars.
I believe your '68 bracketry should look the same as my '69. I don't have the smog pump installed. Ended up going with a 31" alternator belt which is almost too short, but at least I am not at the end of the adjustment. Adjust the PS belt first, then the alternator. Both can be held tight with a second set of hands. I would not be prying anywhere.
Definitely do not use a lever to tighten the alternator. The case is very weak and the lever will go through it which could cause all sorts of new problems.
I know, my original had a hole in it when I bought it unbeknown to me. I found it when I went to have the alternator rebuilt.
Fortunately the hole was in the back half of the case and the shop I took it to had an exact match in their parts pile. I had them transfer over the battery bolt and insulator to keep everything the same.
Notice the offset alternator pulley in this pic, I mentioned in my previous post.
As mentioned try and post some pics of your set up....,.
How have you guys solved this?
Ok, while I was typing my anser, Rebelrob was making the same point
The probem may be the pulley on your alternator. Faster Rat's picture in post #9 shows the correct one quite clearly. According to the AIM, non-ps cars have the second belt sheave driving the alternator.
When you add power steering, the second sheave drives the power steering pump and the power steering drives the alternator, effectively from the third sheave. If you didn't change the alternator pulley it is still aligned with the second sheave.
Of course, if you have AC, you are supposed to have an idler pulley on the first sheave belt...
Reason: Posted after Rebelrob provided same info.
Bob Heine wins the prize for posting the AIM setup - which is absolutely correct BTW.
Faster Rat - agree completely, second set of hands are great when getting the PS pump tight (what a PITA that is) first, followed by alt. nice orange manifold to WP hose there, BTW
Ironcross - mine was originally set up by PO like the ones you show - which was incorrect. It also prevents you easily seeing the timing marks.
Special orange rubber.
I was told by a former NCRS regional chief judge the '69 BB was originally painted that way...clamps and intake manifold overspray included...in about 15 seconds. I hated to do it, but I'm trying to go the original route as much as possible on whatever restoration I do.
DDN, hard to tell from the pic if you have the offset alt pulley.
Also I noticed that your lower alt bracket/strap (last pic-above) is bolted to the upper alt bracket. In the original bbc vette config, this strap is bolted to the water pump via top bolt right side if your standing in front of engine looking at it.
Not sure, but that might give you more tension, or try a shorter belt.
