Flat off idle
Old Jul 14, 2010 | 12:21 PM
ging0023's Avatar
ging0023
Cruising
Default Flat off idle
I have a 78 PC with a rebuilt engine. When we did the rebuild (professional shop) we installed a set of vortec heads, new intake, 650 edelbrock carb, and long tube headers - nothing too drastic. Everything runs great and she goes like a bat out of hell if you mush the go peddle but if you drive it like you aren't a NASCAR driver it has a definite hesitation off idle. It is like the engine is stumbling just for the first 100-150 feet from the stop light.
I have tried my best tuning it with a vaccum gauge (I can get it to read 18) and I set my timing at idle with vaccum advanced disconnected at 32* but I can't get rid of the darn lag.
I am thinking my distributor could use a rebuild because my timing mark jumps around a little +/- 3*. I am also looking at the msd street fire ignition instead of a rebuild.
This is also the first edelbrock carb I have owned and I miss my holley. I would like to go back to a holly but don't have the $$ right now.
Thanks for the help,
Ryan
Old Jul 14, 2010 | 08:55 PM
Rally68's Avatar
Rally68
32 deg advance at idle? You want your initial (idle) timing around 12 - 16 deg with the vac line plugged; your all-in mechanical (centrifugal) advance should be around 36 deg, which will give you approximately 52 deg advance when you have the vac hooked up. Did you adjust the dwell before you set the timing?
Old Jul 15, 2010 | 09:10 AM
ging0023's Avatar
ging0023
Cruising
I didn't think you set the dwell on HEI ignitions. How do I do that? When I plug in my vacuum line to the distributor am I supposed to see the timing jump? It doesn't... Do you think I need to rebuild the distributor or buy a new one?
If I set it at 12* I don't think it really wants to run well. It seems happy at 32*.
Old Jul 15, 2010 | 09:21 AM
hugie82's Avatar
hugie82
If you have the timing mark jumping around on a rebuilt motor 6 degrees there is something wrong in that distributor
Try a different dist. every garage has a chevy HEI laying around. slip one in and see what happens.
If you still have a timing mark jumping around you will need to get into the balancer, timing chain, cam gear, crank gear ect..
Old Jul 15, 2010 | 09:52 AM
ging0023's Avatar
ging0023
Cruising
Ok, I will try that and report back.
Old Jul 15, 2010 | 11:11 AM
GeorgeS's Avatar
GeorgeS
Rally and Huggy are correct. I have a 600 edelbrock on my 327 and it runs fine but there are no adjustments other than idle mixture. If you timing seems to jump or move, I would suspect the Dist. My setup is happy with base timing around 14* to 17*. If your engine doesn't run with that initial timing you may have another issue.
Old Jul 15, 2010 | 03:30 PM
Rally68's Avatar
Rally68
Sorry, I assumed from your comment you had points and were considering the MSD (HEI) dist.
Regardless, I concur with GeorgeS--if your car doesn't run well with 14 - 17 deg initial, you have other issues. Have you verified your damper mark is at TDC for #1?
*IF* you have a manifold vac source (as opposed to ported), when you plug in the vac can, you should notice an increase in idle rpm and smoothness. Timing should advance about 15 deg. If you are running ported vac, you will need part throttle to see the timing advance.
Suggest you read Lars' posts on timing as well as the sticky at the top of this forum... Good luck!
To Flat off idle
