Coil spring removal-Question
Old Mar 24, 2002 | 11:00 AM
72Shark's Avatar
72Shark
Default Coil spring removal-Question
Can I remove the coil springs without a "spring compressor"??? One is available at the local AutoZone, but would save a trip if possible???? :) Thanks for all the help!!
Old Mar 24, 2002 | 11:20 AM
73Ken73's Avatar
73Ken73
Default Re: Coil spring removal-Question (72Shark)
It is much easier to remove the springs with the compressor. I only compressed mine a little bit when I removed them. I think that you could remove them without the compressor. Installing them would be hard without the compressor.
Old Mar 24, 2002 | 11:39 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: Coil spring removal-Question (73Ken73)
I didn't need it. Just use a chain to secure it to the frame for safety.
Old Mar 24, 2002 | 12:07 PM
Black68Vette's Avatar
Black68Vette
Yeah, you can remove them fine without a compressor, but can't install them without. If you are doing the VB&P front transverse mono spring install (like me tomorrow finally!) then you dont need it.
Old Mar 24, 2002 | 01:40 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: Coil spring removal-Question (Black68Vette)
I didn't need them for reinstalling the 460 springs either. I only cut off a half of a loop too. I guess it depends on the brand and rate of the spring.
Old Mar 24, 2002 | 01:57 PM
Scott78's Avatar
Scott78
Default Re: Coil spring removal-Question (Budman78)
It can be done W/O a spring compressor. You need a floor jack and some chain(for safety). It is a easier to install it with a compressor to keep the spring in the pocket, but it can be done.
Scott
Old Mar 24, 2002 | 02:04 PM
SleekLines's Avatar
SleekLines
Default Re: Coil spring removal-Question (Scott78)
Just be careful if you use a chain. Make sure it's sufficient to hold the pressure of the spring. A weak link or small chain could result in damage to you or your car.
I bought a coil spring compressor from Sears for about $35. May be something thats used once in a blue moon, but it's nice to have when needed.
-Sleek
Old Mar 24, 2002 | 02:05 PM
72Shark's Avatar
72Shark
Thanks for the advice on the "chain"!! Damn spring compressor "slipped" and the whole suspension assembly expanded, sounded like a gunshot. Without the safety chain the spring might have killed me! Other than this...looking good so far. Cut 3/4 of a coil because my front end was WAY high, and I wanted a mean low stance. I'll provide progress updates and photos when done!! Thanks for the help! :flag
Old Mar 24, 2002 | 08:54 PM
72Shark's Avatar
72Shark
Done! Looks considerably better, but still not low enough. Cut 3/4 coil out of each side. Think I'll drive her around for a week or so to see if any rubbing or trouble develops. Probably will cut another 1/2 coil next weekend and install the grade 8 bolts (longer) in the rear. Thanks for all the help! :cheers:
Old Mar 24, 2002 | 10:20 PM
TJKirby82CE's Avatar
TJKirby82CE
How did the compressor "Slip"? So I can avoid this next weekend.-TK
Old Mar 24, 2002 | 11:41 PM
72Shark's Avatar
72Shark
Default Re: Coil spring removal-Question (TJKirby82CE)
Not sure how it happened. Heard the "boom" and the compressor was just laying loose inside the spring. Strange...yes...scary....YES! Just use a chain to secure it is my advice! Still kinda spooky though! :eek:
Old Mar 25, 2002 | 05:55 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Are you sure the spring is seated properly in the upper socket. If it isn't, the front end will sit too high. I cut 3/4 off my front coils and the front fender lip is at 26.5 inches. The key to the springs though is the upper spring seated in the socket.
To Coil spring removal-Question
