OK, WTF now?? Help
Old Jul 15, 2010 | 10:22 PM
cherrybombc3's Avatar
cherrybombc3
Default OK, WTF now?? Help
My speedo started to bounce tonight, why?? At lower speeds up to 35 or so the needle bounces about 10 - 15 mph, sometimes more. I mean from 0- 20, boing, boing, boing. If I get up to 55=60 it steadys out. I checked the connection @ the speedo & at the trans & the cruise transducer, all good. Could it be the cruise control transducer gone bad??
Old Jul 15, 2010 | 10:52 PM
tonak's Avatar
tonak
Mine did that and then seized. Conventional wisdom is to pull the speedo cable and lube it. Personally I loosened it from the transducer, shot some wd40 into it and chucked it in a drill. Ran it in reverse, speedo started moving properly and it has been fine ever since. You might have other problems but frequently it is just a lube issue.
Old Jul 15, 2010 | 11:04 PM
cherrybombc3
I'll give that a try as Im sure they have never been lubed since birth. I guess I've neglected to lube ole Girl where it counts, hope she doesnt hold it against me?
Old Jul 15, 2010 | 11:31 PM
tigers123's Avatar
tigers123
Don't overlube it and use the speedo grease for cables that they sell. Overlube can be just as bad as no lube at all. No excess even coating.
Old Jul 16, 2010 | 12:48 AM
TimAT's Avatar
TimAT
My 77 started that too- new cable didn't help. Bearings in the speedo head went away. $125 later it's new again.
Old Jul 16, 2010 | 07:30 AM
cherrybombc3
Did you have it rebuilt, or just buy a new one? If rebuilt, by who??
Old Jul 16, 2010 | 04:51 PM
hugie82's Avatar
hugie82
If it gets better but not 100%, I would just buy new cables. There pretty cheap
Old Jul 18, 2010 | 10:30 AM
cherrybombc3
The lube did the trick! HA! Go figure.
To OK, WTF now?? Help
