Number FRAME??????????????
Old Jul 16, 2010 | 09:02 AM
delgal's Avatar
delgal
Default Number FRAME??????????????
frame number ????????????
hello all, I must find my frame number for my car to pass inspection (required)
Here are some pictures where I look (but I did not have time to brush all)
right side:
[IMG][/IMG]
[IMG][/IMG]
left:
[IMG][/IMG]
could you maybe show me a picture to better locate the chassis number??????
I forgot, it's a C3 1976 !!!!!
delgal
Old Jul 16, 2010 | 09:13 AM
Chuck72's Avatar
Chuck72
It is stamped on the top surface of the frame next to the outside edge, and displays parallel to the outer edge.
http://forums.corvetteforum.com/c1-a...are-frame.html
Chuck
Old Jul 16, 2010 | 09:27 AM
Chuck72's Avatar
Chuck72
Better pic.
http://forums.corvetteforum.com/c3-t...in-number.html
Old Jul 16, 2010 | 09:47 AM
delgal's Avatar
delgal
Default re
there is not another location?(easier access for inspection)
to recall this is a model 1976
Old Jul 16, 2010 | 10:07 AM
72LS1Vette's Avatar
72LS1Vette
There are no other locations other than the 2 mentioned on the frame for the VIN number. You will have to use an inspection mirror to see the number. If your frame is rusty the number may not be readable.
Rick B.
Old Jul 16, 2010 | 10:25 AM
delgal's Avatar
delgal
Default re
[IMG][/IMG]
I found this on the net! it's a crazy story!!
no longer understand anything !!!!!!!
Old Jul 16, 2010 | 11:14 AM
forvicjr's Avatar
forvicjr
Is that your car in the avatar? nice....
Old Jul 16, 2010 | 11:37 AM
delgal's Avatar
delgal
Default re
it will become !!!!!!!! is my project!!
Old Jul 16, 2010 | 11:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Top of the frame rail, driver's side, just in front of the #4 body mount. You might be able to see this stamp if you can clean the area.
Second stamp is here:
You cannot see this stamp with the body on the frame.
Good luck.
Old Jul 16, 2010 | 12:02 PM
delgal's Avatar
delgal
Default re
I'll see !!!!!!!! thank you !!!!!!!!!!
Old Jul 16, 2010 | 01:27 PM
delgal's Avatar
delgal
Default re
I found !!!!!!!!! in a location that is accessible !!!!!!!!!
[IMG][/IMG]
the photo is the black spot (I grind)
But I miss the first 4 digits !!!!!!!!!!!!
Is this normal ?????
Old Jul 16, 2010 | 02:31 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Here is mine and the location. I think you can use a mirror to find it. It will be a condensed version of the VIN.
Name:  Frame VIN 1S115707.jpg
1S115707 is mine on my 1971.
Good luck with it.
David
Old Jul 16, 2010 | 03:21 PM
Easy Mike's Avatar
Easy Mike
I found...in a location that is accessible...
[IMG][/IMG]
the photo is the black spot (I grind)...But I miss the first 4 digits...
Is this normal ?...
I cannot see the number in your pic but it looks like you are very near the correct location.
The stamp is a VIN derivitive; it is not a complete VIN. It probably reads 16S4xxxxx.
1 for Corvette
6 for 1976
S for St. Louis
4xxxxx is your consecutive unit number.
Same VIN derivitive will be stamped on the original engine pad. Your complete VIN is on the driver's windshield post. A complete VIN (13 characters) was not stamped on the frame.
Old Jul 17, 2010 | 03:17 AM
delgal's Avatar
delgal
Default re
Old Jul 17, 2010 | 09:32 PM
joewill's Avatar
joewill
it is too bad your transportation authorities require that, there are so many that have an unreadable number due to rust or previous sandblasting.. you are lucky to even find it on a car that old..
To Number FRAME??????????????
