R-12 how much?
Old Jul 16, 2010 | 08:59 PM
pauldana's Avatar
pauldana
Default R-12 how much?
how many oz does the R-4 1979 A/C system take? I have several bottles of R-12 sitting around....
I vacuumed the system for several hours and it is holding at -20PSI
or what should the high side and the low side read (PSI) when on? is the low side 60psi like home?
thx..
Old Jul 16, 2010 | 09:20 PM
mds3013's Avatar
mds3013
The original sticker from my late model '77 shows 3.0? lbs.. I can't tell if it is 3.00 or 3.08lbs. I don't know if a '79 is exactly the same but should be close. Pressures will vary with outdoor ambient and engine rpm. I normally use the approx. number of ozs. while checking the temp. at registers. Usually 45-50 degres is normal and will cool the car. The small cans are 14ozs.. So if it is 3.08 lbs. will be 49.28 ozs. = 3.52 14oz. cans. mike...
Old Jul 16, 2010 | 09:52 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I vac'd and refilled all 4 of my Vettes last summer. 3 12oz cans should be plenty.
One of them leaked through the main O-rings in the compressor and had to re-do it this past month.
Used a 30lb tank this time and put in just over 2 lbs weight. About 36oz which is exactly what 3 12oz cans weigh.
The chart I've been using for years.....
outside temp70...low23-28...high135-170
outside temp80...low23-29...high170-205
outside temp90...low26-35...high205-245
outside temp100..low31-40...high245-285
Old Jul 16, 2010 | 10:15 PM
pauldana's Avatar
pauldana
Originally Posted by mds3013
The original sticker from my late model '77 shows 3.0? lbs.. I can't tell if it is 3.00 or 3.08lbs. I don't know if a '79 is exactly the same but should be close. Pressures will vary with outdoor ambient and engine rpm. I normally use the approx. number of ozs. while checking the temp. at registers. Usually 45-50 degres is normal and will cool the car. The small cans are 12ozs.. So if it is 3.08 lbs. will be 49.28 ozs. = 4.1 12oz. cans. mike...
cool thank you so much guys!!!
i have 2 cans in right now and it is cool.... so i will monitor the pressure and put in the 3rd
first time the A/C has worked in 20 years
first time it has had any A/C equipment in it for 10 years.....
i am so stocked!!! and its 105 here!!
thx again.. Paul
Old Jul 16, 2010 | 10:42 PM
KapsSA's Avatar
KapsSA
Yikes, 105!!
Didn't think I'd need to list this one.....
outside temp110...low35-44...high285-320
Old Jul 16, 2010 | 11:39 PM
LT1driver's Avatar
LT1driver
what would be the chart data for R-134a systems??????
To R-12 how much?
