My little girl is thirsty.She has begun to drink her collingwater.I suspect that the intakegasket is poor.The car smokes a little bit more when cold from the left enginebank.My Chevy G20(van) had the same problem and it was the gasket.Any other idees? :cool: :cheers:
There are 3 ways I can think of.
1. Intake gasket
2. Head gasket
3. Cracked head
When my truck starting using coolant you can guess it wasn't one of the cheap gasket fixes :rolleyes:
Forgot one, cracked cylinder sleeve. Thats as bad as it can get.
Scott
Ouch...I felt that one in the wallet..block it have only about 3000Km on her since a complete rebuild..Accourding the previous owner,she have been doing this once before,and it turned out to be the gasket..She don`t drink much so i`ll be waiting untill the season ends and take her apart then... :cool:
Theres spring for real in Sweden now..All the blondes a creeping out of the woodwork.. :cheers:
I'd start by pulling the intake and seeing if I could see some "tracking" of the anti freeze below the gasket. More then likely it's 1 of the gaskets(intake or head). Did it badly overheat recently? That is what cracked my head.
Scott
BB I had a micro leak in the radiator. The car leaked 1 - 2 qts of coolant per week
It only leaked when hot and it was soo small that I couldn't see any coolant on my garage floor. The coolant evaporated before it did reach the floor.
Before taking heads off , check the simple items first
