Busted differential, (suggestions welcome)
Old Jul 17, 2010 | 10:56 PM
supervette2's Avatar
supervette2
Default Busted differential, (suggestions welcome)
Well it happened this Saturday night. I went to romp on it and a big BOOM happened. It knocked my head liner down onto my head and a coasted to a stop. I guess my differential didn't like the 16 pounds of boost of the procharger. Anyways I have yet to pull the cover but my left tire axle stub is hanging out of the pumpkin about a half inch or so. My guess is that I snapped a yoke. What are people running for rear end combos that can handle 1000hp? This is my third rear end in the car and this one was suppose to have been heat treated and all that jazz. The first two went on a 400 hp engine and this last one roughly 800. Obviously its not tough enough. Im wondering if I should just put a Moser M9 in? lots of fab work though. Im all ears
Old Jul 17, 2010 | 11:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Not much with an IRS will handle that power I would just go with an 8 inch and be done with it
Old Jul 18, 2010 | 01:28 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Here's an article about 12-bolt IRS differentials that IMHO would be worth a read.
http://www.hotrod.com/techarticles/1...dup/index.html
Yes, as a matter of fact I do happen to have a 12-bolt IRS myself, tho it was done by Henry's Machine Works, but the same guy (Pepe Estrada) who designed it did so for Tom's. Unfortunately, Tom's no longer builds them and AFAIK neither does Henry's, but I know a guy...
TSW
Old Jul 18, 2010 | 10:07 AM
ZZ71S's Avatar
ZZ71S
http://www.digitalcorvettes.com/foru...d.php?t=110048
Heres something to look at
Old Jul 18, 2010 | 12:59 PM
supervette2
wow that looks like a boat load of work. I may just do an autofab.
http://autofabcart.net/1968-1982corv...4-linkkit.aspx
and a moser M 9. Big G is right someone should get one done and computerize it in cad for a program to make them. For now it looks like the solid axle kit is the way to go. The site says it can take 800hp but I wonder if one could make it live with 900? I seen a thread on this forum of some people using it with success.
Old Jul 18, 2010 | 01:13 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
8 inch?
supervette, can we get some pictures of that blower setup?
Old Jul 19, 2010 | 05:44 PM
TheSkunkWorks
Installing the 12-bolt IRS diff itself was a very straight forward task (writing the check aside), and IMHO it's hard to see adding the loops and all as being any more difficult than completely converting to a solid axle, but to each his own...
Old Jul 19, 2010 | 05:53 PM
MotorHead's Avatar
MotorHead
Originally Posted by turtlevette
8 inch?
Finger mistake, I'll try not to let it happen again, pretty sure though anyone with anything between their ears can figure it out
Old Jul 19, 2010 | 07:14 PM
Tom Sarno's Avatar
Tom Sarno
The first question I would like ask is, what are you using the car for? If you are Drag racing there is no reason to have IRS. I know someone road racing a '70 Vette with a solid axle and a modified four link, so I don't see the need to keep the IRS.
No matter how strong you make the differential, with that much HP, the next problem will be u-joints.
If you are drag racing, get the book door slammers, http://www.summitracing.com/parts/CCA-158. This book will take all the guess work out of the modification. I would install a 9inch and have a set of street gears and a set of track gears. Swapping the third member would only take about and hour.
To Busted differential, (suggestions welcome)
