1970 Blower Motor Resistor
Old Jul 18, 2010 | 07:03 AM
Tom454's Avatar
Tom454
Default 1970 Blower Motor Resistor
I spent 3 hours searching for a replacement Blower Motor Resistor for my 70 454 WITH A/C and came up empty handed. Mine is a pile of rust & dust. The GM Parts Catalog (group 9.275) shows 3942651 for 69-71 and 6262652 for 72-82. Corvette Central lists their 453054 but they say it is the 6262652 replacement.... which is wrong for a 69-71. None of the "Supporting Vendors" list this part as far as I can tell. Anybody know what the issue is ? Discontinued ? No longer available ?
Old Jul 18, 2010 | 09:46 AM
Black Stingray's Avatar
Black Stingray
Tom,
I think part # 27260 from Eckler´s is the right part ( ´69 - ´82 )
Uli
Old Jul 18, 2010 | 10:04 AM
...Roger...'s Avatar
...Roger...
Whats the difference , I just looked at 69 , 70 and 74 diagrams and the connectors and wiring is the same in all 3 . Does it just mount different ? If so transfer the new resistors to your old mount.
Old Jul 18, 2010 | 03:40 PM
Tom454's Avatar
Tom454
The Ecklers and Corvette Central part are the 6262652 for 72-82. It looks very similar... but it must be different in some respect. Possibly the resistance of the coils. Too high a value, and the blower will run slow- too low a value, and the fan speed switch can burn out due to too much current flow. Maybe it's just the connector. I honestly do not know the difference. Most of the vendors list the 6262652 for 72-82 and clearly omit 69-71. I can surely order a 6262652 for 72-82 and see what the difference is.... maybe none. I was hoping someone else had gone through this little exercise already. Bummer.
Old Jul 18, 2010 | 04:10 PM
...Roger...
I have the wiring diagrams that show the actual connector that goes on the resistor and they appear to be identical ,including wire color.
Old Jul 19, 2010 | 08:05 AM
Tom454's Avatar
Tom454
I have the Lectric Limited diagram and the factory shop manuals for 1970. The Lectric Limited diagram also covers 1971 wiring and A/C and for 1971 it contradicts itself with a 4 prong plug pic but only 3 connections. The listed Lectic Limited part numbers for the A/C harnesses are also different between 1970 and 1971. I guess Illl just have to order one of the 72-82 type to see for myself.
1970 A/C #VAC6970
1971 A/C #VAC7100
1970 MAIN WITH A/C #VMA7000AC
1971 MAIN WITH A/C #VMA7100AC
Old Jan 11, 2012 | 03:50 PM
Tom454's Avatar
Tom454
Update: I ordered the 1972-1982 A/C Blower Motor Resistor 6262652 and compared it to the original 1970 A/C resistor 3942651. The pin-to-pin ohms resistance of the 6262652 are exactly double the ohms resistance of the 3942651.
Here are pin use & values: (the pins are labeled on the resistor)
3942651 (white mount)
Pin 1 goes to the fan motor +
Pin 4 to Pin 1 (Low Fan Speed) 1.1 ohms (.2 + .4 + .5 in series)
Pin 3 to Pin 1 (Med1 Fan Speed) .6 ohms (.2 + .4 in series)
Pin 2 to Pin 1 (Med2 Fan Speed) .2 ohms (.2)
6262652 (black mount)
Pin 4 to Pin 1 (Low Fan Speed) 2.2 ohms (.4 + .8 + 1 in series)
Pin 3 to Pin 1 (Med1 Fan Speed) .6 ohms (.4 + .8 in series)
Pin 2 to Pin 1 (Med2 Fan Speed) .2 ohms (.4)
This implies that if you use the 6262652 to replace the 3942651 the fan motor will run approximately 1/2 half the correct speed in Low, Med1 and Med2. Hi fan operation is not affected because the fan switch bypasses the resistor and hits the high speed fan relay to drive the fan motor.
Mine is functional because I soldered wires to bypass the rotted spades. But it is butt ugly. Anybody know where the 3942651 can be found??
Note: Non-A/C cars used a different blower motor resistor altogether.
Old Jan 11, 2012 | 09:00 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I probably have an original used one, let me look tomorrow and I'll post back.
Old Jan 12, 2012 | 08:22 AM
Tom454's Avatar
Tom454
I think I found one at Dr Reb. #9220412. I'll call them today.
Old Jan 12, 2012 | 11:29 AM
Tom454's Avatar
Tom454
Update.... Dr Reb part is discontinued. Mine is good except for the corroded male connector tabs. I soldered one back on for a test but it broke off too easily. I'll have to braze new tabs on it.
Old Jan 12, 2012 | 04:31 PM
0Willcox Corvette
Former Vendor
That's bad.. I looked at all the old boxes I have and only have the newer version. One is out of a 75 and appears to be original.
Couldn't you transfer the resistance coils from the original unit to the new one?
Food for thought.
Willcox
Old Jan 13, 2012 | 09:58 AM
Tom454's Avatar
Tom454
Food for thought.
Willcox
I had considered that... they are not welded or brazed... they are crimped. I figured the coils would be made out of stainless.. but they're not. It might be tungsten, nickel-chrome or some other rust resistant alloy. The brackets are made of regular steel... they will rust. I have brazed stainless to copper and other materials. I don't know what this stuff is. Apparently, it needs to be crimped unless that is just a cost saving measure. Anyhow... I could cut the coils off one but have no means of re-attaching them to the other legs.
To 1970 Blower Motor Resistor
