Suddenly soft brakes
Old Jul 21, 2010 | 08:32 PM
bluthundr's Avatar
bluthundr
Default Suddenly soft brakes
I was taking my 76 with power brakes out a few nights ago, about 2 miles from home I notice my BRAKES light on. First thing I do is pull the parking brake up a notch and let it back down. Didn't go out. So I cautiously press on the brakes a few times and they get softer with every press, but still have some brake power. With a little downshifting I make it home fine. Once I get it back in the garage, I pop the master cylinder cover and shockingly it is full of fluid. I look under the car, no drips. I have my wife hold the brake to the floor, no leaks. Proportioning valve is dry too.
So if I had a firm pedal before I left, what would make it suddenly go squishy? I have not re-bled them yet, but if there is air in the lines now, where did it come from?
Old Jul 21, 2010 | 08:41 PM
...Roger...'s Avatar
...Roger...
Air probably came in through the rear caliper lip seals. Try bleeding the rear calipers.
Note which one had air ,that rotor probably has some runout.
Old Jul 21, 2010 | 09:03 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
when you press the brake do you slowly lose pedal like there is a leak? If so the master is bad. You won't see any external leak because the fluid is just bypassing the seals internally.
Old Jul 21, 2010 | 09:10 PM
...Roger...
True but will the master turn the light on ?
Old Jul 21, 2010 | 09:32 PM
turtlevette
yea, you have one circuit putting out pressure and the brake fluid leaking past the plunger on the other circuit causing a differential pressure in the switch.
I'm pretty sure i've experiened that before. I've toasted everything on my car in about everyway possible over 30 years.
it could very well be what you suggested first. just another possibiltiy. easiest thing is to bleed the brakes first as you suggested.
Old Jul 21, 2010 | 10:29 PM
KSM's Avatar
KSM
My master went just a week after I replaced the calipers. Looked for a leak and bleed the system for hours........replaced the master and problem was solved.
Old Jul 22, 2010 | 01:33 AM
elke_10's Avatar
elke_10
had the same issue mine was the left rear sucking in air into the system. there was a very lil tiny spot where it was leaking when breaks applied i mean really tiny. but it was enough to suck air into the system and my breaks got real squishy. i had to drive home with the E-brake oh that was fun .
Found it when i tried bleeding the brakes that my left rear was empty.
Old Jul 22, 2010 | 07:37 AM
bluthundr's Avatar
bluthundr
No loss of pressure while holding the pedal, just not where near as firm as it used to be. I will re-bleed and see what I come up with.
Old Jul 22, 2010 | 08:21 AM
...Roger...
I'll bet you can do this by simply opening the bleeders (1 at a time) on the rear calipers and if you watch closely should be able to see the air come out of a certain caliper. Gravity bleeding no pumping. Believe it or not but I have done this without jacking the car up or removing the wheel ( inner and outer).
I would also bet(but only a dollar)that the RR will be the culprit.
Good Luck and I hope this isn't the start of a body off.
Old Jul 22, 2010 | 11:29 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If you do find air in one of the rear calipers, check for play in the wheel bearing. I've seen wobbly bearings cause this problem. If there is no air try gently pushing on the brake pedal. If it slowly sinks that's a bad master cylinder.
Old Jul 22, 2010 | 12:41 PM
toddalin's Avatar
toddalin
Sounds like "air pumping" through the rotors due to excessive runout (been there, done that, and lost my brakes on the freeway ).
Re-bleed all the brakes and take it up on the road for a cruise. If the problem returns, have the rotors checked for runout.
To Suddenly soft brakes
