AFR 195 heads exhaust port shape
Old 07-22-2010, 04:46 PM
FKING1
FKING1's Avatar
Default AFR 195 heads exhaust port shape
Can someone with AFR 195 SBC heads tell me if the exhaust ports are D shaped.
Nothing on search and AFR has not replied.
My Headman's are D shaped.
Thanks.
Old 07-22-2010, 05:11 PM
Rebelrob
Rebelrob's Avatar
877 892 8844 , give them a call and ask them. They have good tech support.
Probably are D shaped.
Old 07-22-2010, 05:18 PM
FKING1
FKING1's Avatar
Thanks,
Will give them a ring.
Old 07-23-2010, 05:05 PM
FKING1
FKING1's Avatar
They are rectangular not D. Saw one.
Will take a D gasket and check coverage to see if rectangle is obstructed.
Old 07-24-2010, 02:28 AM
SanDiegoPaul
Support Corvetteforum!
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
I'm using the same standard Hedman Headers on my new AFR 195's that I had on the iron heads.
Old 07-24-2010, 10:01 AM
FKING1
FKING1's Avatar
Are the D shaped Hedman ports bigger than the rectangular ports on the AFR's?
Old 08-02-2010, 05:02 PM
FKING1
FKING1's Avatar
Info for anyone doing a future search on this subject.
Took D- shaped gasket for my Hedman's to local speed shop and compared to exhaust ports on AFR 195 (AFR 1034) heads with rectangular exhaust ports.
The D openings are larger than the AFR rectangular exhaust port openings.
So the exhaust gases will flow freely. Yee Ha!
Old 08-02-2010, 05:44 PM
VETDRMS
VETDRMS's Avatar
Interesting. My AFR 195s were D shaped when I received them. However, after I had them ported they were square. They must have stopped using the D shaped port.
Old 08-02-2010, 06:32 PM
cardo0
cardo0's Avatar
Location: Las Vegas - Just stop perpetuating myths please.
Default Quiz for the day: "What is the purpose for the D-port shape"?
The real question is "What shape of header tube do want for a D-port head"?
For street? For race only?
Why did GM use the D-port on the L98 head?
cardo0
To AFR 195 heads exhaust port shape
Quick Reply: AFR 195 heads exhaust port shape
