Blower Fan Rubbing
Old Jul 25, 2010 | 09:48 AM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
Default Blower Fan Rubbing
Had trouble finding a motor and fan that would fit the hole. All is clean in hole. Fan is shorter than original but aluminum. Could something be pushing the backside?
Thanks Gary
Old Jul 25, 2010 | 09:54 AM
...Roger...'s Avatar
...Roger...
Buy the correct fan assembly for your car.
Old Jul 25, 2010 | 10:06 AM
SIXFOOTER's Avatar
SIXFOOTER
Either that or get a C4 fan assy and put in a spacer. C4 fans run faster and move more air
Old Jul 25, 2010 | 11:36 AM
Can't find one Rog.
Old Jul 25, 2010 | 11:37 AM
Couldn't find a spacer either.
Old Jul 25, 2010 | 03:24 PM
SIXFOOTER's Avatar
SIXFOOTER
ya have to make that, I used 2 layers of 1/2" MDF from home depot. Use the fan for a pattern, paint it with black epoxy paint and it will last forever
Old Jul 25, 2010 | 03:34 PM
dannyman's Avatar
dannyman
Didn't you have a thread on that with pictures?
Old Jul 25, 2010 | 03:45 PM
JimT's Avatar
JimT
I've seen several posts stating that a C3 blower fan housing can be fitted with a C4 fan motor and fan, and all that is needed is a 1" spacer. Is that all that is required? No wiring modifications, or reaming out the housing or other changes? I'm looking to improve air flow in my '72 with air.
Old Jul 25, 2010 | 04:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Making a spacer out of 1" plastic is an option or you can make one form 3/4" plywood and paint it black. You really don't need a 1" spacer, 3/4 will work just fine and keeps the blades extra close to the metal backing inside the blower housing.
To make one from plywood simply sit the blower fan on top a square section of plywood. Trace around the fan and then cut out this circle about 1/4" larger than the trace.
Once you have the fan hole, lay the motor back on top with the fan in the hole and trace the outer edge of the blower fan.
For screws... if you go to your hardware store you can purchase the pole barn metal (sheet metal) screws with the neoprene washers on them in 1" or 1.5". These screws seem to be the perfect size for holding the motor in place plus they offer a seal to the motor when installed.
IMHO
Willcox
Old Jul 25, 2010 | 04:16 PM
SIXFOOTER's Avatar
SIXFOOTER
Wasn't mine, but I did it the same way. 2 years ago or something. I might try to find it.
Old Jul 25, 2010 | 04:18 PM
'75's Avatar
'75
I used 3/4 plywood, it kept the clearances tighter.
Old Jul 25, 2010 | 04:22 PM
SIXFOOTER's Avatar
SIXFOOTER
Here is a good one wioth pics
http://www.vettemod.com/forum/showth...ght=fan+spacer
To Blower Fan Rubbing
