My head is about to explode
Looks like there just wasn't enough meat cast into the manifold and it sticks out past the wall of the block. Got a pic of the underside of the manifold?
Seems like the proper way to repair is to build it up on the bottom side with alum tig and refinish the surface.
BTW, the new Permatex stuff mentioned before is some amazing stuff, not RTV, but a new compound. Probably would work, but the cure time might be too fast for a manifold install.
The manifold actually lines up, there just seem to be a spot on the manifold mating surface that makes the gap. Why the RTV doesn't fill that in in the first place I don't know.
There is more to this than meets the eye, speaking of which there is no way you can see it, I even scraped the old RTV off with a razor blade so there is some thing weird going on and I will get to the bottom of it sooner or later.
Maybe someone putting together a motor now with a new Vic Jr can take a close look at it for us
To clean I used a thin rag that I fed through the crack soaked in brake clean,actually I used many rags. I cleaned the @#$% out of it.
I squeezed the Ultra through from the backside and contoured it through the dist hole with my finger.
If there has been RTV in between the 2 surfaces , the surfaces were clean,and the RTV cured completely (which I'm sure they were ) , then IMO I would be looking for Pos or Neg crankcase pressures. Lets face it he did not build this motor to idle back and forth to the grocery store.
Motorhead , was the dislodged RTV outside or inside of the china wall ?
If there is no pressure problems I can think of several ways to secure the RTV depending on how wide the gap is.
good luck my friend, plz keep us posted... p
If pressure is the issue,....what's the work around.
PS..Be sure you unplug all Orifices before Sploding, should minimize the splatter area, dont know by how much though?
Whatever I did last night made the leak twice as bad or more. There was one small pond of oil and above that there was another one but this one was water / coolant I think. It was further back than the bottom of the rad so this is just getting better and better as time goes on. The good news is I should have all the required skills to land a job at BP.
First I'm going to pull the distributor and see if that hole came back but I don't want to speculate right now but the fact I haven't had a 600HP small block that has been revved to 7500RPM's is starting to make me think who the heil knows what's going on at that RPM ?
Are you running two valve cover breathers or just one? I still run just one, and had a thought that maybe two would help this. I may try it myself at some point. Right now I just don't have the time to tinker.
Makes me wonder how everything else matches up like your distributor shaft etc.
Here's the pic, I put a flashlight at the back a directed the light at the hole. You can see the gap about an inch long and 1/16 to 1/8 inch high. And please I really don't need anyone telling me that RTV should have filled that gap as others have had the same problem and the china wall on my Motown block is actually about twice as wide as a normal OEM block and you still get this F ing gap.
I can see why it hasn't been fixed in the 20 some odd years they have been selling them, looks like a pretty tricky milling job and a first year apprentice might need about 5 minutes to fix it
PS I never use RTV around the distributor gasket just so sick and tired of this leak I put it everywhere there was a remote possibilty of a leak
and yet with this vette engine '89 roller 355 engine, I have had some issues, with stockish intakes to boot...an Edel base for a large mouth TPI being the worst...never noticed that gap though....but I found a cure....
idled the engine and sprayed carb cleaner down the back side enough to find the leak, then put a second PCV valve to mani vac in place of the valve cover vent to the induction/air cleaner....
now engine ran at a crank case vacuum.....so to spray some carb cleaner into that spot it was leaking, hear/feel the suction as it was sucked in and cleaning the passages.....not a TON of it, not trying to thin the oil, just clean the leak passage.....
let it dry, then take some RTV on a finger and let it get sucked/flowed into the leak spot....pull the dizzy B+ wire off VERY quickly before all the RTV gets sucked into the engine where it don't belong....
smooth over the outside.....
done deal, no more leaks.....worked for ME....obviously to let cure overnight, and put the normal PCV setup back in position....
with Roger :
