th400 transmission filter
Old Jul 27, 2010 | 06:17 PM
75vetteohio's Avatar
75vetteohio
Default th400 transmission filter
Im trying to change my tranny filter. When i took the old one off it was loose. kinda flopping there. should it be tight against the valve body or loose like it was. .
Old Jul 27, 2010 | 06:22 PM
mds3013's Avatar
mds3013
Should be a bolt with a flat washer that goes through hole in filter and into valve body. Bolt is shouldered and washer is stopped by shoulder. Filter is actually held in place by the washer and shoulder of the bolt holds washer. Does that make sense? I just did mine this weekend but did not take a pic. mike...
Found out washer should not be there. My apologies to all. mike...
Old Jul 27, 2010 | 06:26 PM
75vetteohio
there was no washer on mine when i took it off. After you installed yours could you move it up and down? so the washer doesnt slide over the shoulder, its smaller and the washer holds it secure?
Old Jul 27, 2010 | 06:35 PM
75vetteohio
thanks
Old Jul 28, 2010 | 09:20 AM
STODD's Avatar
STODD
Just did a work truck of mine, along with a shift kit-- it did not have a washer, but a spacer and it is floppy. Most kits now send 2 o-rings for the filter tube, they both do on the tranny side, don't force it, I felt mine was too low and cracked it. Had to go to a tranny place to get a new one.
Old Jul 28, 2010 | 09:27 AM
jimvette999's Avatar
jimvette999
A washer is not needed, or factory. Floppy is normal and (2) 0-rings are a good idea. The filter is designed to float along the shank of the shoulder bolt.
Old Jul 29, 2010 | 07:47 PM
75vetteohio
will it hurt anything to use a washer? I did and it shifts into 3rd now.
To th400 transmission filter
