Exhaust pipe diameter question- OD or ID
Old Jul 28, 2010 | 01:21 PM
Rebelrob's Avatar
Rebelrob
Default Exhaust pipe diameter question- OD or ID
Got a simple question about exhaust pipes and headers measurement.
When one speaks of 2 , 2.5 or 3 inch exhaust etc.., is this size the OD (outside diameter) or ID (inside diameter) measurement?
I am measuring headers and the header collector is 3 inch OD, not ID.
The headers were advertised as 3 inch collectors.
Thanks,
Old Jul 28, 2010 | 01:42 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
The 2.5 inch exhaust pipe I pulled off my 71 was all OD.
Old Jul 28, 2010 | 01:58 PM
sniperdiver37's Avatar
sniperdiver37
Thanks,
Rule of thumb on header is bigger CI bigger headers. SB 2.5, BB 3". most give OD I believe. also unless your motor is super modified keep you exhaust pipes in the 2.25- 2.5 area or you will loose power with not enough back pressure.
Hope that helps
Old Jul 28, 2010 | 02:40 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Hope that helps
Good grief. Will this old wive's tale never die?????
Old Jul 28, 2010 | 03:13 PM
noonie's Avatar
noonie
All tubing (exhaust, brake, plastic etc) is measuered by od, all pipe (under 12") is measured by id.
Old Jul 28, 2010 | 03:33 PM
Rebelrob's Avatar
Rebelrob
OK. That is what I was looking for.
Thank you for the all the replies........
Old Jul 28, 2010 | 03:46 PM
dstaley's Avatar
dstaley
Tubing => specified nominal value refers to outside diameter (O.D.)
Pipe => specified nominal value refers to inside diameter (I.D.)
EDIT: Crap, Noonie beat me to it!
To Exhaust pipe diameter question- OD or ID
