’73 M-20 Muncie wiring question
Old Jul 29, 2010 | 12:24 PM
70_Shark's Avatar
70_Shark
Default ’73 M-20 Muncie wiring question
The transmission has a single(one wire) electrical connector screwed into the side cover below(into) the front shift linkage. What is the function of this switch and what does it tie into?
Old Jul 29, 2010 | 12:59 PM
Les's Avatar
Les
I believe it was part of the emissions system. There's some info about it in this thread-
http://forums.corvetteforum.com/c3-t...-question.html
Old Jul 29, 2010 | 01:54 PM
...Roger...'s Avatar
...Roger...
but that thread is not worth reading IMO.
The switch is for the TCS system , transmission controlled spark.
It will interrupt the vacuum going to the vac advance can on your dist.
For best overall performance bypass the TCS solenoid and go straight to manifold vacuum,switch on the tranny will just sit there.
Old Jul 29, 2010 | 02:18 PM
70_Shark's Avatar
70_Shark
Thanks. There is nothing emissions friendly on this 'vette. I think I will just plug it.
Old Jul 29, 2010 | 04:44 PM
Les's Avatar
Les
Roger,
Thanks for summing it up. I didn't have time when I posted the link to read through that mess again. I think that one poster in particular, who clearly never scored well in the "plays well with others" category, tends to bring out the worst in others.
Old Jul 29, 2010 | 05:03 PM
...Roger...
Roger,
No problem , if the OP read that whole thread he might have needed 1/2 a case of beer to settle his nerves.
Old Jul 29, 2010 | 06:45 PM
Duke94's Avatar
Duke94
Here's a article from a NCRS mag (about 1/2 way down) on the 71' TCS system which is close to the 73'.
Gary
http://ncrsrmc.org/Downloads/Mar-2006-Newsletter.pdf
Old Jul 29, 2010 | 08:13 PM
Les's Avatar
Les
Good point. Sorry I didn't get back to you sooner but I've been drinking heavily all afternoon.
To ’73 M-20 Muncie wiring question
