I'm at the end of my patience. I have a Carter 750 cfm carb on a moderately built 454 fresh rebuild. It drinks gas at a ridiculous rate, and fouls plugs.
I have cleaned/rebuilt the carb 3 times, replaced plugs, and have no vaccum leaks. Also, I adjusted the float levels, and turned off the electric fuel pump, but still no change.
I'm pretty sure that the carb, is not modified in any way.
From: San Diego - Deep Within The State of CONFUSION!
Nahh, not too big. I ran a 780 Holley dual-feed on a 327 in my '56 Bel Air. Of course, it had 12:1 TRW's and a solid lifter cam with a shift point of 8500RPM. But still ....
High float levels? Did you recheck the number you are setting them to? Too cold a plug maybe? How much compression per cylinder?
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Thanks for the sound advice. The 454 is a 10.25 to 1 compression ratio.
I've downloaded a good Carter owners manual with a nice exploded view.
That is mainly how I've educated myself so far.
I want to pursue the jetting issue, but I need to understand the terms as they are labled in the diagram because there are a couple of parts labled "Jets" in the diagram.
Are you refering to the part the metering rods (called "step-up rods" in the diagram) go in?
These are called "Primary metering jets" in the diagram.
By the way, my metering rods are labeled "7147".
I know this is a bit wordy, but none of the terms in the diagram match exactly so I want to make sure I understand all this.
if you are running a dual plane, you could run an 850 or a 1000 and it still would not be too big. Something else is wrong, but dont expect to get 20mpg.....
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Something else is wrong for sure. I would take a look at a 750 or 850 Holley classic like the 4779, nice carb, easy to tune and the price is good too
Yeah, what he said. The Carter isn't a carb to learn fuel curves, jetting, etc on. As Motorhead said, score a 750 Holley on ebay (be patient and you can find a good used one for $50-75) plus a rebuild kit ($28). Jet it according to the Holley charts for that model and you'll be in the ballpark. I have a 750 holley (4779) on my mild 454. LOVE IT! It's perfect!
