Power to manual steering
EDIT: Or, does anyone know of a company that manufactures a MANUAL rack and pinion steering.
Rick B.
http://www.ecklers.com/corvette-stee...1963-1982.html
...probably is the Borgeson part that Rick mentions above?
---Bill.
---Bill.
Rick B.
Why not go straight to Borgeson and fit their # 800108 steering box? It looks to be the same part as Eckler's # 54087. Despite what Ecklers say about having to replace the centre link or drag link with a manual one, their part #54158 is designed to bolt on to your original power centre link, after you have removed your control valve.
Borgeson know what they're talking about, as they manufacture the products right there in the USA. Unlike the factory power steering with a 16:1 ratio and full power boost at all speeds and steering wheel positions, the Borgeson unit is a 21st Century box with an integral power ram and control valve that varies the amount of boost, depending on the steering wheel position.
It gives you a sporty 12.7:1 ratio, which will markedly improve your autocross driving, and will provide almost zero boost in the straight ahead position, but the boost increases the more the wheel is turned towards the lock position, just like in a modern car.
Before you pull the trigger, Jigowatt, try to get a drive of a car with a Borgeson box fitted. You will NOT want to go back to manual steer after that!
Regards from Down Under
aussiejohn
Yes, for an OEM manual steering setup you really ought to get that HD center link redvetracr has available. (I'd pick it up myself for a spare if my budget allowed.)
TSW
